RC2: Bug in Batch renaming and other bugs
Locked
Mike2005
Post by Mike2005 »
@ xnview: first of all I want to thank you for this great improvement of XnView.
I have found following minor bugs:
1) When you search for files and then apply batch renaming to the search results, files are not only renamed but moved to the XnView program folder.
2) Thumbnail details: When you chose the "EXIF: date modified" entry to be displayed, it is only displayed as "EXIF: date modified" when it is the last entry in thumbnail details. Otherwise the "File created date" is displayed instead.
3) Instead of the "File created date" the date of file modification is shown.
4) I'd wish you could add an entry "EXIF: date taken" to the thumbnails details because some raw converters change the EXIF date modified string so it doesn't show the date the photo was shot.
5) Photoshop compatible plugins (.8bf): I tested the PTLens 5.3.4 lens distortion correction filter with the result that after applying it all three RGB color channels are equal so the RGB picture now is looking like a grayscale picture. This problem also exists in release 1.74.
Mike
OL
Post by OL »
1. Confirmed
2. May have been fixed for RC3 as per http://newsgroup.xnview.com/viewtopic.php?t=1947
3. Confirmed
4. Agreed :wink:
5. Confirmed. Not all photoshop plugins works properly in XnView or other apps, unfortunately. I'm not sure it's XnView's fault.
Re: RC2: Bug in Batch renaming and other bugs
Mike2005 wrote:1) When you search for files and then apply batch renaming to the search results, files are not only renamed but moved to the XnView program folder.
Ok, i'll check
Fixed
EXIF: Date modified is not enough??
Is it possible to have the plugin?
Mike2005
Post by Mike2005 »
Many EXIF aware softwares change this field to the file modification date (Photoshop, a minor competitor of XnView :wink:, does so) thus there's no advantage of "EXIF: Date modified" over the "File modified date" entry.
http://www.epaperpress.com/ptlens/index.html
The newest release is 5.5, but the problem is the same as with 5.3.4. The red channel seems to be copied to to the green and blue channel.
I've made the change to support search files. So please, make many tests to be sure all is ok now (RC3).
Dreamer
Post by Dreamer »
Works good in RC3, I'll test more later...
Re: [Fixed?] RC2: Bug in Batch renaming and other bugs
Post by Guest »
OK in RC3.
OK in RC3.
OK in RC3.
Thanks for adding "EXIF: date taken" and ""EXIF: date digitized"!
Seems to be unchanged.
Mike
The Photoshop Plugin issue has been split to topic "Wrong RGB channels when using Photoshop PlugIn".
Closed.
Locked
