Moderators: helmut , XnTriq , xnview
Dreamer
Posts: 4608 Joined: Sun Jul 25, 2004 9:08 pm
Post
by Dreamer » Sun May 22, 2005 7:23 pm
If I go from Browser to Viewer, "File index" (#/## ) is misssing for actual image in the status bar, if I go to next image it's OK.
e.g. 3/12 | Image.jpg | 1024x768 ...
XnView 1.80 <x>
Dreamer on Sat Feb 18, 2006 3:54 pm, edited 1 time in total.
marsh
Posts: 2443 Joined: Sun May 15, 2005 6:31 am
Post
by marsh » Sun May 22, 2005 7:47 pm
It looks correct to me. Because, when you click on first image, would you want
to see 1/1? Also, you would always know what the first image is that you select.
OL
Post
by OL » Sun May 22, 2005 9:01 pm
It doesn't look correct to me (but it's not a major bug)
You double-click any thumb a folder, then must click Next then Back in the viewer to see its index.
ckit
Posts: 2583 Joined: Tue Feb 17, 2004 1:11 am
Post
by ckit » Mon May 23, 2005 5:50 am
Dreamer wrote: If I go from Browser to Viewer, "File index" (#/## ) is misssing for actual image in the status bar, if I go to next image it's OK.
I can confirm this bug, took me a little while though
scratch
Posts: 82 Joined: Sun May 22, 2005 11:23 pm
Post
by scratch » Mon May 23, 2005 7:20 am
caught this myself yesterday (my first day using xnview, actually). minor bug, but still quite annoying.
Posts: 46236 Joined: Mon Oct 13, 2003 7:31 am
Post
by xnview » Mon May 23, 2005 7:40 pm
It's not a bug, when you open a picture i don't import full file list, so i don't know how many files are here. After Next/Previous, i know it
Very annoying?
Olive
Posts: 215 Joined: Wed Oct 06, 2004 9:18 pm
Post
by Olive » Mon May 23, 2005 7:52 pm
No not very annoying, but if you could implement it easily and without degrading performance that would be nice =)
Post
by xnview » Mon May 23, 2005 7:54 pm
Olive wrote: No not very annoying, but if you could implement it easily and without degrading performance that would be nice =)
I've not added it for performance.
Dreamer
Post
by Dreamer » Mon May 23, 2005 11:33 pm
xnview wrote: Olive wrote: No not very annoying, but if you could implement it easily and without degrading performance that would be nice =)
Performance = time? I see no delay if I switch from image without file index to image with it.
It's not very annoying, but if I switch from browser to viewer, often I'd like to see how many images are there...
So if it's easy to do/fix, could you do it please?
If not, never mind, add reply, rename to [OK?] and I'll move it to Solved... forum then.
Posts: 8704 Joined: Sun Oct 12, 2003 6:47 pm
Post
by helmut » Tue May 24, 2005 6:50 pm
It's not a big issue, I think. So if performance (=speed) is affected a lot when fixing this, this should not be fixed.
scratch
Post
by scratch » Sat May 28, 2005 8:18 pm
just curious, how much of a performance hit is there?
Dreamer
Post
by Dreamer » Sat May 28, 2005 9:14 pm
scratch wrote: just curious, how much of a performance hit is there?
Me too.
scratch wrote: caught this myself yesterday (my first day using xnview, actually). minor bug, but still quite annoying.
Yes.
Dreamer
Post
by Dreamer » Fri Jun 03, 2005 11:36 pm
After some testing, I see no delay when "file index" is creating.
Tested with the 1st image (183 images in dir.), go from browser to viewer, press Home key, file index is created = no delay!
Dreamer
Post
by xnview » Sat Jun 04, 2005 7:42 am
Dreamer wrote: After some testing, I see no delay when "file index" is creating.
But if have 10000 images, and sort by date for example, there will be a delay...
Post
by helmut » Sat Jun 04, 2005 11:12 am
For XnView 1.80 I think we just keep it they way it is now. Postponed.
