** English - English
Translation of On-Screen texts of XnView MP and XnConvert
Moderators: XnTriq, xnview
Re: ** English - English
helmut wrote: Wed Feb 24, 2021 10:05 pm XnView 0.98.2
Dialog: InfoIPTC
Copy rights -->
Copyright
Where, i don't have it
Copy in clipboard -->
Copy to clipboard
Positions in Dialog DlgConvertCanvas
Currently:
Top left
Top
Top right
Left
Center
Right
Bottom left
Bottom
Bottom right
Suggestion (see Dialog DlgConvertBorderClass, for example):
Top left
Top center
Top right
Center left
Center
Center right
Bottom left
Bottom center
Bottom right
Do you want to delete all your template's name? -->
Do you want to delete all your name templates?
right thanks
XnView MP 0.99.1:
Finished... -->
Finished.
Finished: %1 file(s) found... -->
<< Back -->
< Back (like in XnResize)
Change DPI -->
Set DPI (like in XnView Classic, EDIT: In XnView Classic menu says "Set DPI..." while dialog title says "Change DPI...")
Modify timestamp, please wait... -->
Modifying timestamp, please wait...
Aborted... -->
Aborted.
or
Stopped. (see below)
Abort -->
Stop (multiple occurences. XnView Classic uses "Stop". Side aspect: Currently, when translating "Cancel" and "Abort" to other languages, this might result in the same translation which is wrong. The term "Stop" might help to avoid this.)
helmut wrote: Tue Oct 05, 2021 9:03 pm XnView MP 0.99.1:
thanks
XnView MP 0.99.6:
Notation:
<section/dialog in QtLinguist> > "<current label>" -->
<suggested label> (<Comment>)
___
FileListWidget > "List" -->
Details (like in Windows Explorer for example)
CategoryView > "Add New..." -->
New album (similar to "New folder", "New category", and so on)
DlgAcquireInto > "An error occurs when saving %1" -->
An error occured when saving %1
Misc > "An error occurs during process!" -->
An error occurred during processing!
PaintDialog > "Do you want to close the draw tools?" -->
Do you want to exit drawing and discard your changes?" (Better wordings are welcome.)
MenuBrowser > "Acquire (TWAIN)..." -->
Acquire (TWAIN) (No elipsis because import/scanning is started immediateyl [unless the TWAIN driver displays a dialog])
MenuBrowser > "Acquire into (TWAIN)..." -->
Batch acquire (TWAIN)... (similar to "Batch rename" and "Batch convert")
DlgAcquireInto > "Batch scanning" -->
Batch acquire (TWAIN) (title of dialog should match the menu item".)
helmut wrote: Fri Jan 07, 2022 5:14 pm XnView MP 0.99.6:
yes thanks
XnView MP 0.99.7:
Notation:
___
DlgConvertTextClass > Anti-Aliasing -->
Use anti-aliasing (similar to "DlgConvertResizeClass")
DlgRotate > Smooth -->
Use anti-aliasing (This suggestions is supposed to be discussed - I'm not 100% sure whether smoothening is the same as anti-aliasing)
right, thanks
