"View as" & filmstrip layout
Lesmo16
Post by Lesmo16 »
Each time you leftclick the "View as" icon, the view is pushed to the next list entry of the ComboBox.
:bug: The first list entry seems to be the actually selected thumbnail view. I don't know exactly because the list is invisible.
In my case it's the Filmstrip layout.
When I step through the whole list and then return at the first entry, I want the filmstrip layout back - but I get something like layout 4.
To get back the filmstrip, I have to reselect it from the main menu. :(
Everyone who believes in telekinesis, raise my hand!
ckit
Post by ckit »
"View As" and Layouts are two completely different features.
You can't get the Filmstrip layout or any layout by using "View As" or F9.
Lesmo16
Post by Lesmo16 »
ckit wrote:"View As" and Layouts are two completely different features.
Yes, that's like it should be - but it isn't :!:
When I'm in layout=6 (filmstrip) and press <F9> or leftclick on "View as",
the layout immidiatly changes to =4.
Now I have to reselect my favorite layout =6!
I hope that's a bug, otherwise it's a very bad behaviour. :?
BTW: I thought that I've declared this thread as [Bug:] - looks like somebody edited it.
Dreamer
Post by Dreamer »
Lesmo16 wrote:BTW: I thought that I've declared this thread as [Bug:] - looks like somebody edited it.
Not me, renamed to [BUG or REQ ?] - let Pierre decides...
Looks as if Pierre has edited the subject (not sure why).
Filmstrip layout is only a real filmstrip layout when it shows thumbnails. This is probably why Pierre made the view change when changing the layout. That's the problem you are experiencing.
The problem is that filmstrip layout is unlike the other layouts. Film strip is actually not a real layout, it's something else. I guess the typical usage is switching from their favourite layout to film strip layout and back. So perhaps the handling should be different from the other layouts. For example a separator and perhaps a different/clearer symbol would help.
Lesmo16
Post by Lesmo16 »
Doesn't matter who was the "Notme" ... :P
Helmut wrote:Filmstrip layout is only a real filmstrip layout when it shows thumbnails.
OK - that's one kind of interpretation.
I'll try to describe it in other words:
When changing "View as", it starts in a specified layout.
There must be an entry, which leads back to that starting layout.
In any case, when the user jumps topdown through the whole list, lately after the bottom entry he must be back in the initial layout!
Helmut wrote:This is probably why Pierre made the view change when changing the layout.
No, on the contrary: he made the layout change when changing the view.
Lesmo16 wrote:Doesn't matter who was the "Notme" ... :P
Right.
Lesmo16
Post by Lesmo16 »
Fixed - very good! :wink:
FYI: INI has to be deleted before!
Aokromes
Post by Aokromes »
I have a feature request about Filmstrip layout, make one with Filmstrip on bottom instead top.
Lesmo16
Post by Lesmo16 »
Oops - it's not completely fixed! :shock:
:bug: It's back when you activate "Use XP style menus"!
Lesmo16 wrote:Oops - it's not completely fixed! :shock:
"View as" doen't return to Filmstrip layout when go back to thumbnail view??
Lesmo16
Post by Lesmo16 »
@xnview:
IF
- "Use XP style menus" is activated and I cycle through "View as" to go back to thumbnail view
THEN
- it doesn't return to Filmstrip layout (it stays in layout 4)
ELSE
- it returns to Filmstrip layout
ENDIF
But nevertheless, this "View as" thing is still buggy.
Pierre, please play a little bit around with it. If you click the ComboBox entries randomly, you will find out that there is more wrong, regardless the state of "Use XP style menus".
@xnview:
IF
THEN
ELSE
ENDIF
i'll fix it
Lesmo16
Post by Lesmo16 »
WOW, this thing is really weird! :shock:
It seems that it isn't only infected by the state of "Use XP style menus".
I've tried hard to recover (describe) this behaviour, but I can't find a regularity. :(
Lesmo16
Post by Lesmo16 »
Lesmo16 wrote:WOW, this thing is really weird!
Well, Pierre - I think you've got it! :D Thanks!
Aokromes wrote:I have a feature request about Filmstrip layout, make one with Filmstrip on bottom instead top.
Hey, that doesn't look bad! I think Aokromes is happy, too. :D
Locked
