Delphi example to read EXIF and write & read IPTC
Nols Smit
Post by Nols Smit »
I downloaded the example GflSDK.20100320.zip from posting http://newsgroup.xnview.com/viewtopic.p ... phi#p82804 but I get the following errors when compiling it:
libgfl.Load gfl: "..\..\..\libW\libgfl311.dll" failed: 126 (0x0000007E) The specified module could not be found.
libgfl.Load gfle: "..\..\..\libW\libgfle311.dll" failed: 126 (0x0000007E) The specified module could not be found.
My effort follows:
procedure TForm1.btnGetIPTCClick(Sender: TObject);
var
iptc_data: PGFL_IPTC_DATA;
i: Cardinal;
s: string;
begin
iptc_data := gflNewIPTC;
try
gflLoadIPTC('D:\My Documents\Delphi\ScannedMaps\Temp\scalledImage.jpg');
for i := 0 to iptc_data.NumberOfItems -1 do
begin
// What now???
end;
finally
gflFreeIPTC(iptc_data);
end;
end;
AmigoJack
Re: Delphi example to read EXIF and write & read IPTC
Post by AmigoJack »
Most recent Delphi interface is 20100321, that's two posts below - you should have read the whole thread.
As for your errors: they cannot be more precise. They already tell you "hey, I cannot find this DLL at that location". So...
  1. Did you download the GFL SDK at all? You need the DLLs to make anything at all. What you have downloaded is not the GFL SDK - it's only the (up-to-date) Delphi interface for GFL SDK.
  2. Have you verified to successfully run the demo at least? The demo also includes code on how to read IPTC.
madiazg
Post by madiazg »
this is the code I use in my program Imagen3D to display data IPTC:
var
  NItems : integer;
  Iptc : PGFL_IPTC_DATA;
begin
    if gflBitMapHasIPTC(gfl_bmp) = gfl_no_error then
    begin
      IPTC := gflLoadIPTC(Pchar(FileName));
      NItems := IPTC.NumberOfItems;
      for i := 0 to NItems-1 do
      begin
        ShowIPTC(Iptc.ItemsList[i].Name,Iptc.ItemsList[i].Value); //procedure that displays the values IPTC
      end;
      gflFreeIPTC(IPTC); //Libera Memoria
    end;
end;
Best Regards...
Miguel Angel
http://imagen3d.site88.net
Nols Smit
Post by Nols Smit »
Thanks for the comments. I got it working now.
Regards,
Nols Smit
