RC2: Preview problem
Locked
UncleRalph
Post by UncleRalph »
When the preview is activated, and I click on it I go in the lite fullscreen mode, then I click again and return in the browser view, and I try to remove the preview from the viem menu something strange happen in the area where there was the preview before. I have different "effect" so is not easy to describe, take a look.
Also, but I don't know if it is sopposed to be like this, if I zoom in/out in the lite fullscreen and I then return in the browser mode, the zoom is retained in the preview.
UncleRalph
marsh
Post by marsh »
I see a slight oddity:
When going back and forth from fullscreen to browser, a ghost of the picture flashes between the borders of the toolbars in the background.
Is that what you see?
UncleRalph
marsh wrote:I see a slight oddity:
Yes, this is one of the "effects"
Try also like this
- load the program
- preview under the folder tree
- double click on the preview image
- double click on the lite full screen image and return to the browser
- remove preview from view menu
- now do whatever you what, resize the border, minimize and maximize the program, double click some thumbnail and return
do you see what I mean? or it's only my computer?
Now I'm investigating and it turned out that the problem is visible for me in the first 4 preview layout (from view menu) not with the 5th one, and a different problem related to the space between thumbnail appear with the 6th layout.
So basically what I think is that when I remove the preview in the 5th case there is a correct reset of some parameter, but this does'nt happen for the remeining cases.
OL
Post by OL »
Yeah same here, the preview pane isn't removed properly after view>preview
OL wrote:Yeah same here, the preview pane isn't removed properly after view>preview
I'll fix it
Danny
Post by Danny »
I don't see anything wrong so i'd say fixed.
Locked
