[Fixed BUT] RC2: Thumbnails & Details - Shadow bug
Locked
ckit
Post by ckit »
If I disable "Use Shadow" in Thumbnail options, the shadows are still present in "Thumbnail & Details" however they're gone in Thumbnails.
As far as I'm concerned Thumbnails and "Thumbnails & Details" are the same and therefore should use the same options unless you want to double-up.
Re: RC2: Thumbnails & Details - Shadow bug
ckit wrote:If I disable "Use Shadow" in Thumbnail options, the shadows are still present in "Thumbnail & Details" however they're gone in Thumbnails.
Right. Regarding the shadow I'd also expect that the setting affects both "Thumbnail" and "Thumbnail & Details" view.
I'll fix it
Dreamer
Post by Dreamer »
Fixed in RC4, but white background is still there - in Thumbnails view it is OK.
Also (in RC3 too) selected file in Thumbnails & Details view doesn't have shadow (if shadows are enabled) - in Thumbnails view it is OK.
Dreamer wrote:Fixed in RC4, but white background is still there - in Thumbnails view it is OK.
Yes normal, selection seems strange with shadow...
ckit
Post by ckit »
This bug has been fixed in RC4.
Locked
