MP 0.26 Mac : Crash at start up !
Moderators: XnTriq, helmut, xnview, Dreamer
cyki
Post by cyki »
Hi pierre!
same problem here like post before but on Mac Leopard Snow
Re: MP 0.26 Mac : Crash at start up !
cyki wrote:same problem here like post before but on Mac Leopard Snow
Did you have previous version of XnViewMP?
cyki
Post by cyki »
sure, I think it was .21 I can try to remove all data from previous version
Try to remove .xnviewmp folder
cyki
Post by cyki »
xnview wrote:Try to remove .xnviewmp folder
did not help.. I got crash message repeatedly when I click Ignore but what is strange that XnView is running and still active
Do you have PDF files?
cyki
Post by cyki »
Oh yes I had a PDF file in startup folder. Problems with loading preview?
Yes, there is a problem to create thumbnail of PDF on mac
sioban
Post by sioban »
Same problem as described : XNview crashes at startup and I am obliged to close and open again a new session in order to erase the message "ignore" (even I force XNview to quit).
On my computer I have many pdf files but none directly in the home directory. The previous XNView's version I used (0.21) ran very well.
Any idea to solve it ? Is it still possible to download the old version 0.21 ?
Thanks for your help.
cyki
Post by cyki »
seems to be problem also somewhere else because when I go to ~/Desktop where is no PDF directly in the folder, XV also crashes repeatingly
Could you send me your email by PM, i would like to send you a test version?
mrelwood
Post by mrelwood »
First thing I did when launching XnViewMP was to remove visibility of all other than image files, but I still get constant crashing and hanging. Kern protection failure, exc bad address, etc. Should I send the crash logs?
One sure way to crash the app is to browse the Folders with arrow keys. If the app stays on long enough for you to do that...
Intel MacBook 2007
OSX 10.6.3.
The package for MacosX is updated, now it works correctly....
mrelwood
Post by mrelwood »
xnview wrote:The package for MacosX is updated, now it works correctly....
Still crashes when browsing Folders with arrow keys, or hovering mouse at the top of the screen in fullscreen.
Edit: The crash is more likely to happen if I uncheck the checkboxes in Options > Browser > File list.
