The 'Up' root folder icon
budz45
Post by budz45 »
hi,
This, as we all know, is the 'Up' icon at the op of any folder directory in XnMP's 'Browser':
I now wish for 3 things:
1. An option to disable showing of the 'Up' icon entirely. Needed feature
2. Another option to use the toolbar's 'Up' icon in the folder instead of the folder types 'up' icon for better distinguishing, I mean like this:
(I used the 'Up' icon from the Browser's toolbar then I took away it's colour)
3. Another option (maybe default too) for a separator between the 'Up' icon and the rest of the folder's items to maintain a folder distinction. It would be for all views. It would look best on the views 'details', 'list' and 'thumb+details':
Image Image
(I added colour on the 'thumb+details' mock-up which shows that we could also have the ability to customize the colour)
Re: The 'Up' root folder icon
budz45 wrote: 1. An option to disable showing of the 'Up' icon entirely. Needed feature
Option/Filelist :-)
Yes right
Please check XnViewMP 0.30
budz45
Post by budz45 »
xnview wrote:Please check XnViewMP 0.30
Thank you so much, feature/fix added :)
