MP 0.26 Win : Crash at start up !
Moderators: XnTriq, helmut, xnview, Dreamer
:arrow: Pierre
:) Hello !
• I just updated MP from the ZIP archive,and get a crash as soon as I start it (without any file or folder from the Desktop icon):
AppName: xnview.exe AppVer: 0.0.0.0 ModName: xnview.exe
ModVer: 0.0.0.0 Offset: 001a94f5
• That didn't occur with the previous 0.25 in the same conditions. :(
- However, it works as it should starting with an image from a button in Total Commander button-bar ! :?
:mrgreen: KR
Re: MP 0.26 Win : Crash at start up !
I can't reproduce, which OS? Do you have tried with clean .ini?
:arrow: Pierre
:) Hello !
• XP-Pro SP2 (Fr) here, 1 GiB of RAM and 2.4 GHz Intel CPU…
• No crash if I rename the INI, but it doesn't help : MP starts with its own folder in the Browser, and it's a snail !
- Scrolling the tree works only by clicking the scroll-bar button (2 seconds to move by click),
- Closing the MP with the [×] Win button needs 4…5 seconds :( It's unusable.
• I repeat : MP 0.25 worked fine and fast with my INI, and I don't wish to remake my whole settings for each beta…
:mrgreen: KR
marsh
Post by marsh »
It has problem if last-used folder doesn't exist anymore. Perhaps same?
Ex:
PathBrowser=Q:/exists/deleted/
Remove "deleted" from ini item, and it works again.
:arrow: marsh
:) Hello B. !
• There was not any "Last used folder" since I started with no INI at all, my usual one being renamed like I said above…
- Well, Pierre has uploaded a fixed version with which I don't get the crash anymore (with my usual INI) … :wink:
:mrgreen: KR
