[Fixed] RC2: Batch Rename - Purge most recent items...
Locked
Dreamer
Post by Dreamer »
If "General > Recent files > Purge 'most recent files & dirs' on exit" option is enabled, purge also items in Batch Rename dialog - Name template and Replace/With.
Re: RC2 BUG: Batch Rename - Purge most recent items...
Dreamer wrote:If "General > Recent files > Purge 'most recent files & dirs' on exit" option is enabled, purge also items in Batch Rename dialog - Name template and Replace/With.
There should be a way to reset all recent files and dirs and clear all "traces". So I second that.
When we see that people need more specific and individual cleaning, we still can introduce ways to do that.
Re: RC2: Batch Rename - Purge most recent items...
Ok, i'll add it
Dreamer
Post by Dreamer »
OK, thanks Pierre.
Locked
