RC2&3 BUG: Mouse doesn't work with videos
Dreamer
Post by Dreamer »
Mouse doesn't work with videos (LMB doulbe click, MMB, RMB context menu)
It's an old (known) bug, but it works sometimes now:
- In viewer, if I click to a white space only, not video - LMB double click works only
- In fullscreen, also if I click to a white space only - LMB double click and MMB works (but in standard fullscreen only)
Also, could you change white background for videos please? Add the same background as for images or custom.
Danny
Post by Danny »
Yes, i can confirm this. Mouse navigation of video files doesn't work the same way as with image files. It should be consistent though.
And yes, it's kinda strange that you cannot change the white default background since you can do it for pictures.
ckit
Post by ckit »
Danny wrote:Yes, i can confirm this. Mouse navigation of video files doesn't work the same way as with image files. It should be consistent though.
The internal player in XnView is limited and always will be which is why the "Use external player" option was added. Besides who wants to watch a video and then move on to another half-way through?
Danny wrote:And yes, it's kinda strange that you cannot change the white default background since you can do it for pictures.
I have raised this issue before and now I that I have use of an external player I simply don't care :)
Danny
Post by Danny »
ckit wrote:I have raised this issue before and now I that I have use of an external player I simply don't care :)
And i don't care that you don't care. If you don't have anything useful to say, don't bother with posting.
ckit
Post by ckit »
Danny, calm down I just didn't want you making a big deal over this.
Right now XnView has much bigger problems then this.
Dreamer
Post by Dreamer »
And I don't care that you don't care that he doesn't care :wink: .
Calm down please.
ckit's extra note was not very helpful, but sometimes it's a bit frustrating when you ask for things and wait for months. All in all: Please be cool, boys. ;-)
Dreamer
Post by Dreamer »
I just saw that Pierre has tried to fix it in 1.80, some mouse buttons work already, so it would be maybe not so hard to fix also other "mouse problems".
If it's possible to change white background colour it would be nice to do it, but if not, there are really "much bigger problems then this" in xnview.
Re: RC2 BUG: Mouse doesn't work with videos
Dreamer wrote:Mouse doesn't work with videos (LMB doulbe click, MMB, RMB context menu)
I have some problems with mouse when you are on the video preview.
But i'll add double click in white space. And same background as images.
Dreamer
Post by Dreamer »
xnview wrote:I have some problems with mouse when you are on the video preview.
Thanks.
To both - standard and lite fullscreen please.
And what about the context menu (RMB), could you also add it "in white space"?
Thanks.
You have it already in RC2
Dreamer
Post by Dreamer »
xnview wrote:You have it already in RC2
Yes but context menu is only in lite fullscreen...
So currently, in RC2 still doesn't work :
In Preview (in Browser) and in Fullscreen lite:
- dbl-click
- MMB
In Viewer:
- MMB
- RMB - context menu
In Fullscreen standard:
All other mouse buttons works good.
Dreamer
Post by Dreamer »
In RC3 still doesn't work :
- dbl-click (works in RC3 but if option "Dbl click or enter to view in fullscreen" is disabled it is still opened in fullscreen)
- MMB
In Viewer:
- MMB
Dreamer
Post by Dreamer »
Not fixed in RC4.
Dreamer wrote:Not fixed in RC4.
I'll fix LMB/RMB/MMB in RC5
Locked
