RC3: Minor suggestion for Batch Rename "#&qu
Locked
Dreamer
Post by Dreamer »
Batch Rename - if "Create new name template when opening dialog" is enabled, # for the first number is used, if I double click to the first row/file, # for the last nubmer is used.
Example:
BMW 530i 2004 001 - original
BMW ###i 2004 001 - if "Create new name template when opening dialog" is enabled
BMW 530i 2004 ### - if I double click to the first row/file
I think the 2nd way is better and should be used also for "Create new name template when opening dialog".
Re: RC2: Minor suggestion for Batch Rename "#"...
Dreamer wrote:Batch Rename - if "Create new name template when opening dialog" is enabled, # for the first number is used, if I double click to the first row/file, # for the last nubmer is used.
Example:
Right
Dreamer
Re: [Fixed?] RC2: Minor suggestion for Batch Rename "#&
Post by Dreamer »
Dreamer wrote:BMW 530i 2004 001 - original
Fixed in RC3, but - (minor) - "Start number" is not taken from the last number as if I double click to the first row/file.
If i dbl click on such file "BMW 530i 2004 101 - original.jpg", so template will be "BMW 530i 2004 ### - original.jpg", and start number 101.
you have not the same?
Dreamer
Post by Dreamer »
xnview wrote:If i dbl click on such file "BMW 530i 2004 101 - original.jpg", so template will be "BMW 530i 2004 ### - original.jpg", and start number 101.
No this works good but...
...if "Create new name template when opening dialog" is enabled and I select few files, press F2, then "Start number" is not taken from the last number of the first file/image.
Of course this is really a small bug but sometimes you need to rename e.g.:
...if you removed some images between to:
Dreamer
Post by Dreamer »
Problem above is not fixed in RC4 - last used number is used instead of last # of the 1st selected file.
Dreamer wrote:Problem above is not fixed in RC4 - last used number is used instead of last # of the 1st selected file.
Ok, i fix it
Dreamer
Post by Dreamer »
Fixed in RC5.
Locked
