Bring back - "open only one view for multiple files.."
budz45
Post by budz45 »
Hi again,
After UI drag n drop is added to XnView MP, I would like to see the old feature returned of: "Open only one view for multiple files (startup and drag n drop)"
In XnView MP "options" it should go under Options>Interface ... Just a suggestion of where it could go.
PS. If "xnView enqueue all" feature was to get supported then I plan to enable this same "open only one view for multiple files.." feature and use the 'enqueue all' with it, that is from when manual highlighting multiple image files in explorer/file manager. Would be so sweet. :D
budz45
Re: Bring back - "open only one view for multiple files.."
Post by budz45 »
yes, is needed in the Settings>Interface
budz45
Post by budz45 »
I'm so sorry this old tickbox feature already exists in XnView MP :D - it's just that it has been renamed to "Multiple view for same file"
found in the XnView MP's Settings>Interface. Sorry about that, topic needs to be moved to resolved. :wink:
