Translations
Moderators: XnTriq, xnview
Translations
Translations of the on-screen texts are included in the download packages of XnView MP. If you want to get the most recent translations for XnView MP you download them here: http://download.xnview.com/XnViewMP-translation.zip
___
XnView MP - Translations - Discussions
There's a discussion topic for each language. If you have found a bug in a translation or want to suggest a change, please post in the appropriate discussion topic.
Armenian ->Discussion
Brazilian portuguese ->Discussion
Czech ->Discussion
Dutch ->Discussion
French ->Discussion
German ->Discussion
Italian ->Discussion
Japanese ->Discussion
Norwegian ->Discussion
Polish ->Discussion
Portuguese ->Discussion
Russian ->Discussion
Simplified chinese ->Discussion
Slovak ->Discussion
Spanish ->Discussion
Swedish ->Discussion
Traditional chinese ->Discussion
Ukranian ->Discussion
___
Czech ->Discussion
Dutch ->Discussion
French ->Discussion
German ->Discussion
Polish ->Discussion
Slovak ->Discussion
- Moderator
Re: Translation
Thank you for the updated translation tool and files, Pierre. In the German .ts file I see many entries marked with "obsolete" - couldn't these all be removed? Or is there a reason to keep those entries?xnview wrote:Updated for version 0.30
Re: Translation
you have a history in qtlinguist, but you can remove them if needed...helmut wrote:Thank you for the updated translation tool and files, Pierre. In the German .ts file I see many entries marked with "obsolete" - couldn't these all be removed? Or is there a reason to keep those entries?xnview wrote:Updated for version 0.30
- Moderator
Re: Translation
Will XnView MP beta 0.33 need an updated translation?
Re: Translation
updated for 0.34. Please note that in 0.33 and 0.34 there are no new strings.
- Moderator
Re: Translation
Is there an update for XnConvert 1.50 beta? See latest post in 'Non-translatable strings in XnConvert'.
- Moderator
Re: Translation
When using XnView MP 0.53 I've notice that quite a number of strings are not translated to German. When looking in more details, I found that strings that had been translated to German in XnView MP 0.51 are no longer translated (e.g. "Check for program updates") . Not sure whether this also applies for other translations.
Re: Translation
right, you need to validate these strings in qttranslator, i don't know why... I have updated the translation package.
- Moderator
Re: Translation
I've just opened and compiled the xnview_de.ts file and copied the result (xnview_de.qm) into the appropriate language folder. And: All German translations appear properly. So a verification is not needed, just a proper compile is sufficient.xnview wrote:right, you need to validate these strings in qttranslator, i don't know why... I have updated the translation package.
@Pierre: Could you please check whether you can do the compiles for all languages?
Re: Translation
Only compile? Strange. Perhaps i forgot to update .qm in 0.53, i'll checkhelmut wrote:I've just opened and compiled the xnview_de.ts file and copied the result (xnview_de.qm) into the appropriate language folder. And: All German translations appear properly. So a verification is not needed, just a proper compile is sufficient.xnview wrote:right, you need to validate these strings in qttranslator, i don't know why... I have updated the translation package.
