RC3: Thumbnail in TC integration
Moderators: XnTriq, xnview
Icfu
Post by Icfu » Wed Jun 08, 2005 1:24 pm
It's a question, you should have only high quality if option/Browser/thumbnail/high quality is enabled
Like I said, this setting has no influence, it's just the same as I have reported in the Total Commander RC1 thread. Setting on/off, it doesn't matter, no difference in quality.
Icfu
Post by xnview » Wed Jun 08, 2005 2:34 pm
I've checked with RC5, and it works...
SanskritFritz
Post by SanskritFritz » Wed Jun 08, 2005 5:46 pm
Icfu wrote:BUT, it is ALWAYS used, regardless if the high quality setting in XNView is activated or not
Same here.
There's no place like 127.0.0.1
Post by xnview » Wed Jun 08, 2005 6:25 pm
Same here.
If you use embedded thumbnail, i extract always thumbnail from jpeg file, and resize it to the wanted size. So here high quality is not used.
SanskritFritz
Post by SanskritFritz » Wed Jun 08, 2005 7:10 pm
No embedded thumbnail here, but I found the problem. TC starts an own XnView instance and leaves it running. So if I change something in the options in XnView (which is another process), and want to see the result in TC, I have to kill that process first. Then it is working, so now I can switch between high quality and simple mode.
I must say, even with high quality, the thumbnail generation is very fast, much better than explorer, thanks!
Lesmo16
Post by Lesmo16 » Wed Jun 08, 2005 7:25 pm
SanskritFritz wrote:No embedded thumbnail here, but I found the problem. TC starts an own XnView instance and leaves it running. So if I change something in the options in XnView (which is another process), and want to see the result in TC, I have to kill that process first. Then it is working, so now I can switch between high quality and simple mode.
Thanks to you too, SanskritFritz - you've got it! :D
Everyone who believes in telekinesis, raise my hand!
Icfu
Post by Icfu » Wed Jun 08, 2005 10:50 pm
Thanks for that discovery, SanskritFritz. :)
@xnview:
The funny thing is that I have not only shut down XnView for testing purposes but I have also restarted TC but still the setting was not remembered. Things like that really drive me mad...
The problem is that I usually just press a button to restart TC with a small restarter app that closes and recalls the TC instance. Unfortunately the separate XnView thread started by TC is not killed then.
During all the tests I haven't checked Process Explorer, too bad. ;)
Icfu
Hacker
Post by Hacker » Fri Jun 10, 2005 10:54 am
I confirm all of the above findings.
Roman
P.S.: Sorry again for the delay.
Hacker
Post by Hacker » Tue Jun 14, 2005 9:38 am
Same here.
Why is high quality not used? In another thread (about embedded thumbs option and high quality option) you write you use high quality when resizing larger embedded thumbnails.
Roman
Hacker
Post by Hacker » Tue Jun 14, 2005 10:24 am
Also, XnView remains in memory after TC requests thumbnails from XnView. Who is responsible for closing XnView afterwards? XnView or TC?
Roman
Lesmo16
Post by Lesmo16 » Tue Jun 14, 2005 10:46 am
Hacker wrote:Also, XnView remains in memory after TC requests thumbnails from XnView. Who is responsible for closing XnView afterwards? XnView or TC?
Yes, this a very important question - and the last thing to be solved for TC integration.
Any clarification or at last a solution is highly appreciated.
Post by xnview » Tue Jun 14, 2005 1:32 pm
TC closes XnView
Lesmo16
Post by Lesmo16 » Wed Jun 15, 2005 8:14 pm
TC closes XnView
Yes, you're right, it's TC's task - found the same with IrfanView. Of course I've deleted it after testing. :mrgreen:
So IMO this is fixed in RC7
