RC3: "View as" toolbar button displays em
Locked
Post by Guest »
"View as" toolbar button displays empty menu when the arrow is clicked. The correct number of entries are created, but they are empty.
XP Home SP2
ckit
Post by ckit »
Exit XnView, rename your xnview.ini and let XnView create a new one.
Post by Guest »
Thanks ckit! That did it.
Re: "View as" toolbar button displays empty menu
Guest wrote:"View as" toolbar button displays empty menu when the arrow is clicked. The correct number of entries are created, but they are empty.
Could you send me your old .ini file?
Dreamer
Post by Dreamer »
Same problem (with new 1.80 skin), also with "Sort by" button, in RC2 with old .ini from 1.74, sent to Pierre earlier.
With ToolBar 5 skin (xnview restart is needed) there are even no "View as" and "Sort by" buttons.
Old toolbar have not the same items, i wait new version from authors.
Lesmo16
Post by Lesmo16 »
ckit wrote:Exit XnView, rename your xnview.ini and let XnView create a new one.
It works first - but that isn't the complete solution!
Because:
If you activate General -> Startup -> "Use XP style menus",
the "View as" and the "Sort by" ComboBoxes are empty again. :(
Everyone who believes in telekinesis, raise my hand!
Same here
:arrow: Lesmo16
:) Hello !
the "View as" and the "Sort by" ComboBoxes are empty again. ;)
- Confirmed here, even under Win 98 SE with a fresh remade INI…
:mrgreen: V G
ckit
Post by ckit »
I've tested for this bug with and without the XP style menu's and with or without new INI files and have found that the bug does not exist under Windows 2000 SP4.
Dreamer
Post by Dreamer »
Fixed - Win XP SP2.
What about Win 98?
Dreamer
ckv
Fixed in windows 98
Post by ckv »
Dreamer wrote:What about Win 98?
Fixed in RC4, 'Use XP style menus' on or off
Fixed!
:) Hello !
- Confirmed : fixed here too with RC4 under Win 98 SE :D
:mrgreen: K R
Locked
