BUG: Inconsisent File Sorting bug.
Gerrit
Post by Gerrit »
There really is a weird bug in the sorting method of XnView.
For example, having 2 files, Xnview sorts them like this :
WinMerge (16x16)2.ico
WinMerge (16x16).ico
So if you use an explorer which sorts correctly, doubleclicking WinMerge (16x16).ico will show the file in Xnview, however when you then click the "Show next image" shortcut, it skips over the WinMerge (16x16)2.ico file, because, for some reason Xnview thinks filename2.ext comes before filename.ext :?
The weird thing about it, is that it behaves correctly in another example, for instance, it correctly sorts these files :
Notepad2 (16x16).ico
Notepad2 (16x16)2.ico
Please, this is a serious misbehavior/bug, you didn't answer my 1st post about this misbehavior, I really hope you will take this problem seriously.
Re: BUG: Inconsisent File Sorting bug.
Which sort method do you use in browser?
You have an order different from browser filelist?
Gerrit
Post by Gerrit »
xnview wrote:Which sort method do you use in browser?
Hi Pierre,
Sort Order = Name (Numeric) + Ascending
xnview wrote:You have an order different from browser filelist?
The Xnview browser filelist sorts them incorrectly too, like i explained in top post.
Windows Explorer file browser sorts them as they should.
Gerrit
Post by Gerrit »
Nobody taking this serious ? Not even willing to test it yourself ?
It takes only 1 simple minute though....
Gerrit wrote: For example, having 2 files, Xnview sorts them like this :
I have tested, and i have
rra
Post by rra »
sorting JPG-files in browser-mode using Exif-date is also wrong,
I tested this in 197.2 on XP-sp3.
The filesorting on Exif-date works fine in the windows-explorer.
Rene
You have that in XnView:
rra wrote:sorting JPG-files in browser-mode using Exif-date is also wrong,
If you have 2 files to test?
rra
Post by rra »
I am sorry, Xnview does seem to work OK, :(
for some reason my camera had the year set wrong in its menu,
so also in the Exif date for the last photo's.
Rene
Gerrit wrote:Nobody taking this serious ? Not even willing to test it yourself ?
Which OS do you use?
Gerrit
Post by Gerrit »
Pierre,
I use XP 32bit (SP3).
:-( I use the same OS... In windows explorer, you use 'sort by filename?
stockelgurph
Post by stockelgurph »
Heya!
Given is a folder with these files:
dir /b
which is the same order when sorting by file name in Windows Explorer ...
This is what XNVIEW does:
0ca2309c621a3bbceed9a3730f9ee2da
0f3f22a332fdebd007749cc62f2fa0e1
1c823d777a7ad5a4b8f9b9b558976dd2
1d5c802d21c90786266df6d1e2b3418c
2ddf2dacac2555c4dcdb14e7a31cac40
3b5e19abc9618f92528603e25fac5e00
3c49a8fc3d2eb58910ccb439b41ecf5f
3d1a97f513cad21f46d89300c02a75af
3dbbe3db76b5ca16ef3f256e3d49705a
3fe05bb14e95d602dc3505aaa011ce55
4a6cde39d48f63b19327658e5ff5babb
4e2ddb369caad525808a25639ebeb360
4e5531aaa8643b1b55d1f1641e4c927f
5c3cf1b399233c61e562d367509595bf
5f6381dcd96dbf06f80b0714b5a008ae
6b731c809e8082baaaeaecd09190afa9
6d62b76ab78eac7bc1869e0352a8f2c4
7a07ee286c28b2697716beb40076b8d6
7f1cf2ceda496bea0f5ffee9621f09bc
8bf578c54efe3020c2f85f69b78840dc
8f050c1cce3b222bae52f7e91f920cd1
9dfc3516e5c2ca9317e9d08d0dd38777
9e503785d91e5af5c451b53a8de142cf
25c8f90b3a7add38fb507761b92e345c
28b2638f7ac3233a2fcd5461e0eb83ec
28d894dbc468e462218ba3ceda49da61
30ff01cd6c7932f17b920fd7dabd580d
38c4f79965e3e24be1d06af32785fa1d
53ec2e8797bb2b0a59fd87b921127ddf
76f30d241ea27187d257cbfabba319bb
77e5614322cc6263425f5d1a76a096f6
92f1e51dc3a8fb211a52e3c5a300b8fd
028db151f7f76d709dbae1bb4f3b0f35
056ff9e13d69373ce0acbfe363840c24
195ea0536089e99cef6a4eab0afefd71
403ecc5e9aa2b22c9788ca3b4b573081
580fe759973591b908fe689dea60b64d
601c7dd972cf3a850c538b45ee157407
693a814b4f7ee5c4072c9f4190107537
724fdca11b5ab7553f888c0d38a177f3
774c789ba5335b55ff1be7899a736bdc
931e1c8b2495ab7d5874c7822bdd57ba
975bde4be7b78fe9c13bfa02b1bda8b6
8013e0e9d99175ae71aa7d994ed13861
8706cc5b77289207e04fd0f531177ae6
15125a3ef78e53b9666bcabc3e6d4a9d
95639d6ee3db33c56c708f7cbd84a87d
909500a03bd737d065f8c4c0107b7294
07615392a267e597a7b3b16eb2eb5391
829761853110f88db4a1c4ff22982255
09810703701795d4e27711b74d885e81
a93fb766a660c124a355cfa59fb0caa0
a9503e92835884890b4d4840a47b84ec
bcee5e2f4421088d12aa79d97eb537e5
bf4de9cae504bee539e81da0351bdfb2
c1a40a2ff4decbe4430736fdfd93a7f0
c5fd98b74425e0d3f5517b45c6f3f410
c01a926d9db0bdab9643a47705d85603
c59b990a1c91845d262b475c80714593
d1fdfd61fb5710eb2039e86e349da7ad
d5b1f79e9cce5932729e7e4606fb4fd7
dcb2d072a445c23efa740c0be6ef99ba
dfb71046c96b83c40901222d365aa81d
eb9e570ab30fabd9d1a88be9c09d9cea
f5d408b04dd77cab7cc48e7b5ec1d55c
f5f923c72b660807480493656a41b807
f46471197392aa156fd3cbbc4a1e7b5f
fa5951f470406f798cb48976fa01c34c
ff200252de057181ea809657c05fd855
Just does not make any sense whatsoever to me, too.
Might this be ...
http://support.microsoft.com/kb/319827/en
I'd be more inclined to call it InsaneSortOrder [tm], Microsoft calls it "is different ... than". Very funny of them indeed ... ... well ... NOT! :( (One of the 50000 settings nowhere in user interface that you have to painstakingly search for on the Internets ... Next stop after going to Windows XP from 2000 right now might be Nautilus on Linux ?? ... which amazingly ALSO has a DIFFERENT insane sort order and differentiates between lower and upper case AND you can't use e.g. "_" in front of a filename to get it before anything else ... Linux has really grown up in the last 10 years as well, they no longer care about what many people might be used to and thus usability, as well ... If you have to spend months searching for settings like these before getting fully productive again after "updating", that MUST be a "mature" operating system ... Sorry, rant over.)
Do you maybe mimic the InsaneSortOrder [tm] that was introduced with XP ?
I'd strongly suggest making this an option in XNVIEW settings ("Do you want INSANE file name sort order?" "No, thank you!" ;) ) or at least sync it with the setting in (HKCU or HKLM)\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
OS here also XP SP3.
Thanks!
Gerrit
Post by Gerrit »
Any news on this please ?
Can we expect it to be fixed in upcomming version(s) ?
