RC3: 'Dbl Click or enter to view in fullscreen'
Locked
marsh
Post by marsh »
Users may confuse this option with traditional v.1.74 fullscreen mode instead
of "Expanded Preview Mode". It might help to rename it.
Dreamer
Re: RC2: 'Dbl Click or enter to view in fullscreen' confusin
Post by Dreamer »
marsh wrote:Users may confuse this option with traditional v.1.74 fullscreen mode instead
And even if it is disabled, and I double click on preview it is opened in fullscreen (lite).
Double click in preview must not open lite fullscreen???
marsh
Post by marsh »
I'm completely wrong about this subject.
'Dbl Click or enter to view fullscreen' is perfectly clear. I was simply confused
by another bug. No problem.
Dreamer
Post by Dreamer »
xnview wrote:Double click in preview must not open lite fullscreen???
Yes, e.g.
[enabled] Dbl Click or enter to view in fullscreen - dbl click on thumbnail and on preview opens image in fullscreen (lite)
[disabled] Dbl Click or enter to view in fullscreen - dbl click on thumbnail opens image in Viewer, but dbl click on preview opens image in fullscreen (lite)
So I suggest the same way or add different option for dbl click on preview.
Yes, e.g.
Ok, i'll fix it
Dreamer
Post by Dreamer »
Fixed in RC3, thanks Pierre.
But 'Dbl Click or enter to view in fullscreen' is not accurate now, since "Enter" always view in Viewer.
So I suggest to rename / remove "Enter" or add separate option for Enter:
[x] - Enter to view fullscreen
I think some users might miss this option.
Dreamer wrote:Fixed in RC3, thanks Pierre.
It's an error, i'll fix it
Dreamer
Post by Dreamer »
Problem above fixed. There is another topic for "new names...", therefore moved to "Solved".
Locked
