RC2: Folder Tab mode automatically activated
ckit
Post by ckit »
This bug wasn't present in RC1
1. In XnView Browser Mode -> No Folder Tabs
2. Double-click on any file
3. It opens in View mode but with Folder Tabs active!
XnView 1.80 <x>
Post by Guest »
Confirming. Then when you middle click to full screen the "tab banner" is still there.
Re: RC2: Folder Tab mode automatically activated
ckit wrote:This bug wasn't present in RC1
So View/Folder tabs is not set, you open a picture in view, and the tab appears, right?
ckit
Post by ckit »
Yes
ckit wrote:Yes
Sorry, i can't reproduce it. In options, what do you have in FolderTabs?
ckit
Post by ckit »
I had everything unchecked.
Of course, at the moment I'm experimenting with Folder Tabs turned on.
I think "No thumbnail in folder tab" should be renamed to "No icon in folder tab"
ckit wrote:I had everything unchecked.
I don't udnerstand, i can't reproduce it...
ckit
Post by ckit »
1. Check that all Folder Tab options are unchecked
2. Exit XnView -> Restart XnView
3. In XnView Browser Mode -> No Folder Tabs present!
4. Double-click on an image file
5. It opens in View mode but with Folder Tabs active!
I can send you my XnView INI file if you would like to check it or play with it.
ckit wrote:1. Check that all Folder Tab options are unchecked
Alwayls no folder tabs :-( Please, send me your .ini
If "Always folders tabs" is disabled, View/Folder tabs is enabled, so when you open a picture, folder tabs is showed. It's normal.
ckit
Post by ckit »
Ok, it just looked like a bug thats all.
This will need to be well documented before 1.80 final is released.
Dreamer
Post by Dreamer »
"Always have folders tabs" option is confusing for me...
Dreamer wrote:"Always have folders tabs" option is confusing for me...
Perhaps it would be clearer if it was named "Use folder tabs even for one window". (Native speakers please correct if needed).
OL
Post by OL »
Hide the tab bar when only one window is open?
OL wrote:Hide the tab bar when only one window is open?
"Hide the tab bar when only one window is open" or "Use folder tabs even for one window"???? "Use folder tabs even for one window" seems better for me...
Locked
