File Associations are NOT working on Windows 7
budz45
Post by budz45 »
dear developer,
please check on Windows 7 if file associations and Xnview file icons are being registered on Windows 7 because when I used I could not get them to work.
Maybe it was UAC? But I currently cannot check this issue right now sine I installed Windows 7 and went back to Vista for a while but I just wanted to raise this issue just for your own analysis.
Re: File Associations are NOT working on Windows 7
I've tried and no problem to set/unset file associations...
Mazek
Post by Mazek »
budz45, it's not just you
I am also having similar issue here. Sometimes the changes you make to file associations don't stick next time you launch XnView. I'm guessing Its a problem with UAC. Shouldn't the app ask for admin permission so it could make changes to registry when users change the options in file association?
