RC1: dbl. click or enter to view fullscreen, Tabs
Locked
cybolon
Post by cybolon »
Bugs in XnView 1.80 RC 1
By marking "dbl. click or enter to view in fullscreen"
pics are not shown as "fit ... all" (which I have chosen as default),
there is no zoom, hitting Pos1 or End does not work
and using pg-up / pg-dwn results in jumping "pagewise", not pic-wise.
AND: Using Tabs makes me crazy:
In some cases, the "browser" tab appears at the right or in the middle of others.
I hit "esc" to close a picture and what I really closed was the "browser" tab.
Another time I hit "esc" and exidently close the program.
Okay, I love all the rest of your new release but I leave
"View / browser tabs" unchecked (waiting for the final).
Thanks again for that perfect picture viewer!!!
:D
Dreamer
Re: dbl. click or enter to view fullscreen, Tabs
Post by Dreamer »
cybolon wrote:By marking "dbl. click or enter to view in fullscreen"
Just few of many issues of the new lite fullscreen mode.
Therefore I suggest options:
"Use special lite fullscreen mode only at xnview start"
and "Never use special lite fullscreen mode"
Or another solutions - more here - if you want, support those ideas or add your own there.
Also any ideas and problems about the "lite fullscreen mode" add there.
Fixed
You have hit ESC when browser was non active and the browser has been closed??
cybolon
gulp
Post by cybolon »
Well...
After trying many times to reproduce,
I realized: Browser was active!
Gulp!
The problem seems to be in front of the computer (user) ;-) Closed.
Locked
