XnView Shell Extension
Moderators: XnTriq, xnview
gitts
Re: XnView Shell Extension
Post by gitts » Wed Jan 12, 2011 5:05 am
xnview wrote:
gitts wrote:just downloaded & set up XNview and the Shell extension
I cannot get the shell extension to show upon the context menu
I am using win7 64bit
Do you have installed XnShellExt 64bits?
yes i downloaded the Xnshellest 64bit
Post by xnview » Wed Jan 12, 2011 8:57 am
gitts wrote:yes i downloaded the Xnshellest 64bit
And no error with the setup??
Post by xnview » Wed Jan 12, 2011 1:22 pm
tissou wrote:[
But, i didn't succeed to get xnview calling 'gfpSavePictureIsSupported', 'gfpSavePictureInit', and all other exported functions related to save method.
thank you pierre for spending time to answer my questions.
Please contact me by email
gitts
Post by gitts » Wed Jan 12, 2011 10:29 pm
No error
gitts
Post by gitts » Wed Jan 12, 2011 11:21 pm
Poblem solved...friend told me to delete and reinstall it and it now works fine
thanks for you help
lochkelly
Post by lochkelly » Fri Mar 09, 2012 7:36 pm
I hate to be stupid, but just how do I get the Shell Extension to work. I downloaded and installed the 64 bit version as I have Windows 7 64 bit. Aren't I supposed to see file icons for WPG files in Windows Explorer just like I do for JPG or GIF files, etc.? I even have WPG files associated with XnView... Is the only way to see them to right click and select XnView?
Thanks for the help.
Lisa
Post by helmut » Wed Mar 14, 2012 8:42 pm
lochkelly wrote:I hate to be stupid, but just how do I get the Shell Extension to work. I downloaded and installed the 64 bit version as I have Windows 7 64 bit. Aren't I supposed to see file icons for WPG files in Windows Explorer just like I do for JPG or GIF files, etc.? I even have WPG files associated with XnView... Is the only way to see them to right click and select XnView?
The XnView Shell extension extends the Windows Explorer. When installed properly, you will see a thumbnail when right clicking on a file in Windows Explorer, just like it is shown in the original post. Additionally, various actions are available which can be performed on the selected image.
After downloading the XnView Shell extension, you have to register it. To register, double-click on the file "register.bat" and registration is performed (you will need admin rights).
mrfalli
Post by mrfalli » Fri Jun 22, 2012 3:07 pm
I noticed some interesting thing regarding the XnView Shell Extension Preview.
It shows parts of a picture that has been cropped(!) before.
The picture I got is cut out from a bigger one. A portrait.
But when I look at it in shell extension, i see the whole(!) original picture. But only there.
Where is this "missing" data stored, and can I reproduce the total picture?
Thank you very much!
Post by xnview » Fri Jun 22, 2012 3:25 pm
mrfalli wrote: It shows parts of a picture that has been cropped(!) before.
XnShellExt use embedded thumbnail
ZoNi
Post by ZoNi » Thu Jan 03, 2013 7:28 pm
What is going on with bug - slow open of context menu when right click some mp4 video files?
Post by xnview » Fri Jan 04, 2013 1:28 pm
ZoNi wrote:What is going on with bug - slow open of context menu when right click some mp4 video files?
Fixed in last version :)
ZoNi
Post by ZoNi » Fri Jan 04, 2013 6:37 pm
Thank you, seems it is OK now :)
CreativeWorld
Post by CreativeWorld » Thu Apr 11, 2013 9:45 pm
How to open embedded cover from mp3 file through xnview shell ext file menu in xnview? It opens audio file, not the image.
HeadCrab
Post by HeadCrab » Fri Apr 12, 2013 1:52 pm
Solved my problem with XnView Shell. I have Windows 7 x64. After install XnView, go to C:\Program Files (x86)\Graph\XnView\XnShellEx and run unregister.bat. Then delete folder XnShellEx. Now download http://download.xnview.com/XnShellEx64.zip and unzip it to C:\Program Files (x86)\Graph\XnView\. And finally run register.bat in XnShellEx64.
Hope it help to someone)
Philip Goddard
Post by Philip Goddard » Sat Apr 13, 2013 10:32 am
The shell extension hasn't been working for me for ages now - I see now that it's probably because of my change over to x64 Windows 7 some time ago. I've now attempted to install the 64-bit shell extension, after successfully unregistering the 32-bit version, but attempts to register the 64-bit version using the bat file (contents: regsvr32 "XnViewShellExt64.dll")just get an error message, telling me that the dll had been loaded but the call to DllRegisterServer had failed, with error code 0x80070005 - so I'm still without XnShell function. I'm currently using Win8 x64.
Philip
