XnView Shell Extension
Moderators: XnTriq, xnview
lostinpixels
Re: XnView Shell Extension
Post by lostinpixels » Thu Jan 31, 2019 6:59 pm
I just tried in a brand new installation in virtualbox (Win10 1809 RS5 october update).
as a try i just unpacked the zip to the desktop, run the register.bat and tried rotating an image - it worked.
when i tried previously (1709), i could not get the register.bat to work - with an error message about failed call to RegSvr32 - I registered it manually which did work.
one more thing, i'm also running filemenutools, a context menu application (a must have) - but i never had conflicts with it..
will continue exploring - thanks Pierre
Post by xnview » Fri Feb 01, 2019 7:55 am
emmequ wrote:
Wed Jan 30, 2019 5:28 pm
xnview wrote:
Tue Jan 29, 2019 4:15 pm
could you try the new version?
yes, last time i already tried new version ;)
which windows version do you have?
Post by xnview » Fri Feb 01, 2019 7:57 am
strange, i've tried on win10 1803, and no problem too
lostinpixels
Post by lostinpixels » Sun Feb 03, 2019 4:28 pm
Ok, i clean installed windows 10 1809 (x64) on my main pc (can you believe i did all this just for xnview shell!) :shock: :)
strangely it still did not work. then i deleted the registry key and right clicked again - this time the menu worked. however it is not consistent: If i R-click on a JPG some items will work and some won't:
convert into = ok (any format)
convert... = not working (works for other formats)
resize = not working (works for other formats)
rotate = not working (works for other formats)
options = not working (works for other formats)
so, not sure what is going on here but hope it may help
emmequ
Post by emmequ » Sun Feb 03, 2019 5:12 pm
4.0.3
if work also me can format the pc.... XnShell is great! :D
Post by xnview » Mon Feb 04, 2019 1:55 pm
If you right click on a png file, all works??
which filename for example?
Do you use english for XnShell?
Post by xnview » Mon Feb 11, 2019 1:02 pm
sandwich
Post by sandwich » Thu Feb 14, 2019 9:52 am
Hi! Thanks for an awesome little program. It's one of the first things I install after reinstalling Windows. ;)
I was wondering, what are the chances of XnShell supporting SVGs?
fs999
Post by fs999 » Tue Oct 01, 2019 3:28 pm
I have installed latest version of XnView Classic with Shell Extension.
I can see thumbnails and miniatures from CDR files in XnView but not in Explorer.
Is there a way to correct this ?
Kind regards
Frederic
GrayWolfson
Post by GrayWolfson » Tue Dec 10, 2019 10:35 am
Hi, please add support webP and HEIC images in XnView Shell Extension Image
Post by xnview » Wed Dec 11, 2019 10:34 am
If you put Plugins\libwebp.so in the folder of XnViewShellEx?
GrayWolfson
Post by GrayWolfson » Wed Dec 11, 2019 3:35 pm
I was able to turn on WebP support (for Win10, x64). Thanks a lot.
To do this, need download "libwebp.dll"
https://www.opendll.com/index.php?file- ... t&version=#
And place it in the "Plugins" folder
