XnView Shell Extension
Moderators: XnTriq, xnview
Re: XnView Shell Extension
Post by xnview » Wed Dec 12, 2018 4:18 pm
i've tried with Photoshop CC 19.0, Win 10, and no problem here
Paultx
Post by Paultx » Wed Dec 12, 2018 4:48 pm
Paultx wrote:
Wed Dec 12, 2018 3:40 pm
Maybe it's also a matter of file size, memory, etc. Just thoughts to help you find a fix. Good luck!
I just remembered that a friend had problems with large files and the solution I gave to him was to increase the memory for thumbnails in the extension options:
sprayer, I recommend you have a try on this.
Desktop: Windows 10 Pro 64-bit • Intel Core i7 • 12 GB RAM
Laptop: Windows 10 Pro 64-bit • Intel Core i5 • 6 GB RAM
sprayer
Post by sprayer » Thu Dec 13, 2018 8:49 am
Thanks, i will try to reinstall windows and all programs later.
In 3ds max dialog it's works too, so maybe something with my photoshop
emmequ
Post by emmequ » Sun Jan 13, 2019 10:05 pm
dear @xnview i have windows 10 pro 64nit 1803 version.
i'm very happy to see that there is a new version 4 of xnshell that for old version don't work. i try to uninstall and reinstall many time, i also installed xn classic (i already use xn convert) but the shell extension don't work.
can you help me.
thanks for your great software
Post by xnview » Mon Jan 14, 2019 1:24 pm
do you have installed the x64bits version?
emmequ
Post by emmequ » Tue Jan 15, 2019 7:41 pm
yes, i tried on 3 different PC with win 10 64bit.
i try exe and zip installation... in the second if i click the register.bat there is an error
i try also 32 bit .
i will be very happy if i can back to use xnschell like win 7.
thanks for availability
2019-01-15 20_38_44-Action Centre.jpg (60.42 KiB) Viewed 4043 times
Post by xnview » Wed Jan 16, 2019 1:12 pm
which error do you have?
emmequ
Post by emmequ » Wed Jan 16, 2019 5:56 pm
every function that i try don't work. i click and nothing is happening.
there is something that i need to set after installation?
i need to have another software installed further xnview classic?
thanks
Post by cday » Wed Jan 16, 2019 7:19 pm
To be absolutely clear, you are using XnShell 64-bit on your Windows 64-bit?
Have you tried with Admin rights, in case that could be a factor?
Otherwise, could this possibly be due to a security issue with ever-changing Windows 10?
emmequ
Post by emmequ » Wed Jan 16, 2019 8:05 pm
thanks for availability, I'm sorry for my problem.
I confirm that i tried with 64bit extension with administrative rights.
I don't have antivirus or any other security protection.
Do you confirm that the 4 version can work on last win 10 pro version?
I read about "registration" of shell but if i click on bat file in the zip mode version i have a register error. possible?
Post by xnview » Thu Jan 17, 2019 11:46 am
yes, and you have the same problem on 3 PCs? Even 'Options' does nothing?
emmequ
Post by emmequ » Thu Jan 17, 2019 4:56 pm
nothing...
i attach one video screenshot
XNshell.mp4
Video screenshoot
(1.59 MiB) Downloaded 54 times
Post by xnview » Fri Jan 18, 2019 10:44 am
nothing...
could you please try to install the CRT
emmequ
Post by emmequ » Fri Jan 18, 2019 5:30 pm
i give up.
i tried also to disinstall all xn software + vcredist_x64 and reboot any time. reinstall all and rebot but don't work. i think that there is some of my software that caused an incompatibility.
After i tried also a register with bat file.
thanks for support
2019-01-18 17_43_49-Start.jpg (29.04 KiB) Viewed 3950 times
2019-01-18 17_43_36-Clipboard.jpg (14.83 KiB) Viewed 3950 times
Post by xnview » Sat Jan 19, 2019 8:21 am
Same thing?
you need to run the .bat with admin rights
