RC1: BMF files
Locked
Hacker
RC1: BMF files
Post by Hacker »
The BMF_read.dll library doesn't seem to be used anymore to read BMF files. XnView doesn't recognize these files even though the file is in the Plugins folder and I have Tools - Options - General - Startup - Use all formats available checked.
Roman
ckit
Post by ckit »
Most likely that plugin has not been updated yet.
You should only have 3 plugins (mpeg.dll,slide.exe and xjp2.dll) in your plugins folder at the moment.
Hacker
Post by Hacker »
Do the plugins need to be updated for the new version?
TIA
Roman
Hacker wrote:Do the plugins need to be updated for the new version?
Yes, please wait the updated plugin
ckit
Post by ckit »
There's nothing to retest, final version will have the updated plugins.
Locked
