Thanks Pierre,
The GPS coordinates within "straight" NEFs now lists correctly but the coordinates transferred from that file type via "Open GPS Location ..." remain in error.
Regards
PETER
NEF embedded GPS Coordinates Error - partial fix
Re: NEF embedded GPS Coordinates Error - partial fix
After a couple of days of further use, the problem remains. EXIF listing is correct and transferred coordinates incorrect. Here is a screen capture of the error:xnview wrote:I can't confirm
- Attachments
- nefgpserror.jpg (247.31 KiB) Viewed 2353 times
Pierre,xnview wrote:Could you send me the file?
I installed Beta 2 and rebuilt the thumbnails in my current working folder and now the geo coordinates of the NEF in the illustration above are transferred to web browser and displayed correctly (as is the case with other NEF images). ???
As an aside, the thumbnail right-button "Open with" is still not displaying the custom options.
Will keep you posted.
PETER
yesPSHRutPark wrote:As an aside, the thumbnail right-button "Open with" is still not displaying the custom options.
After a few days, forced rebuild of thumbnails seems to have fixed the problem.PSHRutPark wrote: I installed Beta 2 and rebuilt the thumbnails in my current working folder and now the geo coordinates of the NEF in the illustration above are transferred to web browser and displayed correctly (as is the case with other NEF images). ???
PETER
Is there a reason why this would fix it?
PETER
GPS is saved in xnview.dbPSHRutPark wrote: Is there a reason why this would fix it?
