Sometimes you want to place VB or Delphi code snippets in your post. It is recommended to enclose the code with the [code] [/code] tags to improve reading.
When previewing your new post and you see the [code] [/code] tags instead of a nice formatting, uncheck the option "Disable BBCode in this post".
Please try to keep your example as short as possible and strip off as much ballast as possible. Stripping your code down is also a good idea when trying to solve a problem...
Using code in posts...
