Free unsharp mask plugin?
All non-XnView related: softwares, formats, imaging, photography...
GeorgD
Post by GeorgD »
Hi, sometimes I want to use an unsharp mask (german: unscharf maskieren) because it produces better results than usual sharpen. I did not find such a function in XnView & plug ins, and searching the www I did not find a cost free suitable photoshop plugin. Do you know one? Thanks, Georg
In the XnView Wiki, you can improve the user guide / documentation / F1-help for XnView (classic/Windows) and for XnViewMP
Moderator & Librarian
Re: Free unsharp mask plugin?
:-) Hello Georg,
you're not alone:
GeorgD
Post by GeorgD »
Thanks XnTriq, good to know I'm not the only one :-) They do ask to include an unsharp mask into XnView - I'm already happy to have a free Adobe Photoshop plugin :wink: Of course, I can use GIMP for it, but it takes so long to load, adds once more JPEG loss, etc. so something I can call from within XnView viewer would be great.
GeorgD wrote:They do ask to include an unsharp mask into XnView - I'm already happy to have a free Adobe Photoshop plugin :wink:
James V. Ryan: AstroPlugins » AstroUnsharp.8bf
rra
Post by rra »
seems to be very interesting,
unfortunately some of the (eg AstroUnsharp.8bf) are not available,
the link is dead to them,
do you know of any other links towards these plugins ??
René
rra wrote:seems to be very interesting,
Twin Peaks Observatory: Various Photoshop Techniques and Tricks » 7c
rra
Post by rra »
Thanks XnTriq ,
but still I am out of luck today:
the plugin crashes on me immediately, (I use windows -7 , 64 bit);
I tested them quickly on an XP - 32 bit system, and there they seem to work OK.
René
And what about AIM USM?
rra
Post by rra »
Yep ,
this one works, even on the 64-bit system.
Thanks, that filter has a lot of parameters,
so it needs some experimenting .
René
  • James V. Ryan: AstroPlugins » AstroUnsharp.8bf
    “This the automation of Jerry Lodriguss's real unsharp routine.”
  • Accurate Image Manipulation for Desktop Publishing: FilterFormula Plug-ins
    “DeepSpace* filters are created with a new version of the FilterFormula/ATS filter engine that enables filtering in the higher bit-depth mode in Photoshop. It is also enhanced in many other aspects over the version 1.12. DeepSpace filters work both in the 15-bit/channel and in the 8-bit/channel modes of Photoshop.”
    • USM*
      “UnSharpMask filter”
    • Sharpen 7-band
      “Powerful sharpening filter, effect is controllable over 7 tonal bands. It utilizes the popular unsharp mask over 3x3 kernel (the same as radius 0.5 in Photoshop). The possibility to adjust the sharpening amount over the 7-bands provides far better quality than a simple threshold cut.”
  • Reindeer Graphics: Select Edges
    “The Select Edges plugin is a powerful tool for selective processing. You can select edge detail in your image for sharpening with Unsharp Mask without getting halos or switch to the inverse selection and use Gaussian Blur to diminish the background.”
  • Xero Graphics: Freeware » Classic Collection » Clarity
    “This filter does a simple but useful job – it clarifies an image, improving colour and perceived sharpness. It is similar to PSP's built-in ‘Clarify’ filter, but doesn't reduce saturation as much as that version seems to do.”
  • Photo-Plugins: High Pass Sharpening
    “This is a plugin to sharpen photos with the classic high pass method. The user can adjust the high pass filter radius, and control the blending with the original image. A high pass output preview is also available to help the user adjust the filter radius up to the point the edges to be sharpened show up.
    High pass sharpening is generally considered to produce less halos and other sharpening artifacts than USM.”
  • Kevin Anetsberger: Sharpenz
    “Did you ever wonder why the blur filter is adjustable but the sharpen filter isn't? I did. So I made one.”
GeorgD
Post by GeorgD »
XnTriq, it's again and again surprising what you digg out of the information space :) In Win 7 64 bit, easy.filter Sharpen by Alois Zingl works and provides classic "unsharp mask" (I also like to curves plugin).
:!: 8-) :!: Starting with v0.94, XnView MP comes with integrated unsharp masking :!: 8-) :!:
  • RC Filters
    “The unregistered filters will save images up to 720 pixels in width and/or height.”
    • Fine USM Sharpen/Deblur
      “Fine USM Sharpen/Deblur gives you full control over the unsharp masking and deconvolution processes, including halo elimination, luminosity mode, very high amounts, edge masking, and blend ranges.”
    • Very High Radius Unsharp Mask
      “High-radius low-amount (HiRaLoAm) unsharp masking is a technique for increasing local contrast, or ‘clarity’. It involves first applying a Gaussian blur to a copy of the image, then subtracting the blurred image from the original. The blur radius is large compared to that used for conventional sharpening, often an appreciable fraction of the overall image dimensions. Unfortunately, the blur algorithms used in most software are necessarily approximations to a true mathematical Gaussian blur, and tend to depart from the ideal at large radii. This limits the usefulness of the technique when editing large images, such as those with dimensions of 4000 pixels or more. Even when high radii are available, the final result is often very different from the preview, and the intended effect may be impossible to achieve.
      The Very High Radius Unsharp Mask filter takes advantage of the fact that since the blurred image contains no fine detail, it can be greatly resized with little effect on the final result. In use, a copy of the original image is reduced in size, comparable to the image preview itself, and a similarly-scaled blur applied. The blurred image is then enlarged to the size of the original image, and used as the unsharp mask. The resulting image is very similar to the preview, even if many times its size.”
<!--// Please refer to Google Translate for an English version of the German quotes. //-->
GeorgD wrote: Tue Oct 27, 2009 12:52 pmIn Win 7 64 bit, easy.filter Sharpen by Alois Zingl works and provides classic "unsharp mask" (I also like to curves plugin).
free.pages.at is down, but there's a mirror on members.chello.at.
easy.Filter Sharpen
easy.Filter Sharpen
Versetzt Schärfen:
Versetzt Schärfen ist eine spezielle Methode zum Schärfen von Bildern die vergrößert wurden. Dabei entstehen beim (bikubischen) Interpolieren typisch weiche Kanten. Durch das Versetzt Schärfen werden diese zur Kante hin durch Pixelverschiebungen geschärft und es fallen die beim normalen Schärfen üblichen Kantenüberzeichnungen weg. Hauptregler ist der Radius und entspricht dabei in etwa dem Faktor der Vergrößerung. Wird er zu groß gewählt, so gehen Details verloren und es entstehen Artefakte. Die können in Kombination mit “Effekt” zur Verfremdung eingesetzt werden.
Unscharf Maskieren:
Der USM-Filter entspricht dem internem USM-Filter von Photoshop mit zwei Verbesserungen. Zum einem wird nur der Luminanzkanal geschärft, es entstehen also keine Farbränder wie in Photoshop. Zum anderem wird der Sättigungseffekt bei Kantenüberzeichnungen gemildert. Beide Schärfemethoden können zur Verbesserung auch optimal kombiniert werden.
Der Filter eignet sich für Grau- und RGB-Bilder mit 8 und 16 Bit.
The following is an excerpt from the user guide for another German freeware tool called JPG-Illuminator (stand-alone):
JPG-Illuminator benutzt zum Schärfen eine sogenannte Unscharfmaske. Dabei wird eine unscharfe Version des Bildes berechnet und vom Original subtrahiert. Es entsteht so ein Zwischenbild, das im Wesentlichen nur die Kanten enthält. Dieses Zwischenbild wird zum Original hinzuaddiert, um die Kanten zu verstärken. Der gesamte Vorgang wirkt sich nur auf die Helligkeit der Bildpixel aus, Farbunterschiede werden nicht verstärkt, da sonst bunte Flecken oder Verfärbungen an farbigen Übergängen entstehen könnten.
Folgende Parameter steuern die Arbeitsweise des Schärfungsfilters:
  • Der Parameter “Radius” bestimmt, wie unscharf die subtrahierte Maske gemacht wird. Je größer dieser Wert, desto breiter und ausgeprägter werden die Schärfungskanten. Für Bilder, die in 1:1 Ansicht betrachtet werden, benutzt man gewöhnlich relative kleine Radien zwischen 0,5 und 1,5. Es entsteht so eine feinere Bildwirkung, da auch kleine Details von der Schärfung erfasst werden. Für hochaufgelöste Bilder die z.B. gedruckt werden, oder Bilder, die aus größerem Abstand betrachtet werden, sind auch höhere Werte nützlich.
  • Die Einstellung “Stärke” legt fest, mit welcher Intensität die berechneten Schärfungskanten zum Originalbild hinzuaddiert werden. Welche Werte sinnvoll sind, hängt stark vom Bildmaterial und dem persönlichen Geschmack ab. Generell benötigen feine Masken mit kleinen Radien höhere Werte als grobe Masken.
  • Die “Schwelle” bestimmt, wie groß der Unterschied zwischen Original und Unscharfmaske sein muss, um berücksichtigt zu werden. Durch den Schwellwert lässt sich verhindern, dass feine Störungen wie z.B. Rauschen durch den Schärfungsvorgang mitverstärkt werden. Beträgt der Schwellwert Null, wirkt die Schärfung bereits bei sehr feinen Strukturen mit voller Intensität. Die beste Einstellung hängt sehr vom Motiv und dem Rauschgrad des Bildes ab. Meist werden Werte zwischen 5 und 20 benutzt.
Große Schärfungsradien ab 4 kombiniert mit einer geringen Stärke führen zu einer Erhöhung des lokalen Kontrasts im Bild. Auf diese Weise kann man Strukturen im Bild betonen, ohne den allgemeinen Kontrast erhöhen zu müssen.
Da bei der Schärfung eines Bildes das Rauschen besonders stark hervortreten kann, enthält der Schärfungsfilter noch die Option das Bild zu glätten. Die Glättung arbeitet natürlich auch ohne Schärfung (Stärke der Unscharfmaske auf Null) und kann so als reine Rauschunterdrückung eingesetzt werden. Meistens wird man den leichten Schärfeverlust durch die Glättung jedoch durch etwas Nachschärfen ausgleichen wollen. Der Regler “Feine Störungen” bestimmt die Stärke des Glättungsfilters. Mit Hilfe des linken Lupenfensters kann die Wirkung auf die Störpixel und die Kantenwiedergabe gut beurteilt werden.
Die Schärfungs-Parameter “Radius” und “Schwelle” lassen sich mit der Taste “als Vorgabe” als Standardwerte festlegen. Wird später ein anderes Bild geöffnet, genügt die Aktivierung des Schärfungsreglers, um genau diese Parameter auf das Bild anzuwenden. Die Parameter zum Glätten und zur CA-Korrektur werden nicht als Standard-Werte gespeichert und sind nach dem Öffnen eines neuen Bildes immer Null.
JPG-Illuminator
JPG-Illuminator
