[Fixed] RC1/2: Copying/Moving Folder doesn't work
"Added : Folder can be Copied/Moved" - it doesn't work - I tried Ctrl+X/C/V and the context menu.
Also "Paste" is missing in the context menu if it is used in empty space, e.g. create new folder, go inside it and do RMB click.
Another minor sugg. - Add F7 next to New Folder in the context menu.
Re: RC1: Copying/Moving Folder doesn't work
By drag&drop i meansDreamer wrote:"Added : Folder can be Copied/Moved" - it doesn't work - I tried Ctrl+X/C/V and the context menu.
rightAlso "Paste" is missing in the context menu if it is used in empty space, e.g. create new folder, go inside it and do RMB click.
And couldn't you add it? I really miss this featurexnview wrote:By drag&drop i meansDreamer wrote:"Added : Folder can be Copied/Moved" - it doesn't work - I tried Ctrl+X/C/V and the context menu.
You have "Copy to" & "Move to" too, it's not good??Dreamer wrote:And couldn't you add it? I really miss this featurexnview wrote:By drag&drop i meansDreamer wrote:"Added : Folder can be Copied/Moved" - it doesn't work - I tried Ctrl+X/C/V and the context menu.- I must switch to another program, do it and return to xnview...
It's not enough for me - I don't like the folder tree, I'm using arrows, enter and Ctrl+X/C/V all the time.xnview wrote:You have "Copy to" & "Move to" too, it's not good??
I'm also using Alt+left/right in my file manager to move back and forward as in internet browsers, it's very easy and fast (I can use also my mouse, 4th button+scroll for that), it would be nice to have it also in xnview (I guess it was requested before).
And I also found a bug
Dreamer et al,
Yet, XnView is XnView and not MS Explorer for images. Just wanted to make you aware of this, nothing more.
you are all aware that we currently try to make XnView do everything MS Explorer does (and hopefully a lot more). This is a good idea, since handling of files and handling of images is basically the same thing.Dreamer wrote:I know you are busy, but this is very important for me (not a bug, but Ctrl+X/C/V for folders).
Dreamer et al,
But with each enhancement we should ask whether this is really XnView's business. E.g. XnView should for example never offer the functionality to establish connections to network drives.
XnView should be able to manage images, files, and folders, and do this well. So your desire for Cut/Copy/Paste is good and important, and should be really supported in one of the next releases or even in 1.80.Dreamer wrote:OK, I just wonder that xnview can do so many advanced operations and cannot do so "basic" operation (copy and move folders).
Anyway I know Pierre is trying to solve it / fix it and I don't know how easy or hard it is, but I believe he will do all he can...
I think "copy/move folders" (with Ctrl+X/C/V and the context menu) is a standard and basic option, so it is XnView's businesshelmut wrote:But with each enhancement we should ask whether this is really XnView's business.
Maybe it could be even a bug
Ok, i've added it. But please make many test to check if there is no problem with folders (drag&drop, ALT+C/M, CTRL+X/C/V)...Dreamer wrote:I think "copy/move folders" (with Ctrl+X/C/V and the context menu) is a standard and basic option, so it is XnView's businesshelmut wrote:But with each enhancement we should ask whether this is really XnView's business..
Maybe it could be even a bug- if I use the context menu > copy (or cut) on folder and try to past, it is not possible.
