[OK] RC1: Batch Rename - move thumbnail above "Old name
Locked
Dreamer
Post by Dreamer »
Batch Rename - move thumbnail above "Old name" - Old name and New name length is very important, more important than number of files / rows.
You could save some space, e.g. place "Start" and "Step" into one row...
Also you could add some image info next to the thumbnail.
Re: Batch Rename - move thumbnail above "Old name"
Dreamer wrote:Batch Rename - move thumbnail above "Old name" - Old name and New name length is very important, more important than number of files / rows.
Not sure that i can put above the thumbnail. Perhaps i must grow up the dialog in width??
Dreamer
Post by Dreamer »
xnview wrote:Not sure that i can put above the thumbnail.
Why, it would be difficult to change or there would be not enough rows?
xnview wrote:Perhaps i must grow up the dialog in width??
But there would be lot of space above and below then. I'd prefer thumbnail somewhere else than next to "old/new names" - it's a little bit atypical too, rather above or below, if you could also save some space...
But if it's too difficult to change, never mind, not so important.
Not sure whether long filenames are needed often. But I can imagine that some people have problems with the current size. So we should do something about this.
When moving the thumbnail you have to redo the design of the dialog. This is why Pierre is hesitant.
I've changed the existing design and made a draft:
http://www.sfp-online.de/xnview/web/tem ... ame101.png
The layout does not look as neat as the current design, but it's also o.k..
Dreamer
Post by Dreamer »
helmut wrote:I've changed the existing design and made a draft:
Yes this is better.
I'm using 3rd layout with a preview on left, therefore I think "it's a little bit atypical" too.
Maybe I'll try to create some draft too, with a preview on left side :wink:
Dreamer wrote:Maybe I'll try to create some draft too, with a preview on left side :wink:
You can try to make a better one, but be aware that there are other dialogs with preview (e.g. Open / Slide Show / ...). Most of them have the preview on the right side.
OL
Post by OL »
helmut wrote: I've changed the existing design and made a draft:
Nice layout! add a grey border around thumbnails, maybe.
helmut wrote:Not sure whether long filenames are needed often. But I can imagine that some people have problems with the current size. So we should do something about this.
Ok, i'll change.
Dreamer
Post by Dreamer »
xnview wrote:Ok, i'll change.
Thank you Pierre :)
Dreamer
Post by Dreamer »
Done, thanks Pierre.
Locked
