Non-Translatable strings [All languages]
Group for those who want to contribute in the area of translation of On-Screen texts or Online help of XnView Classic
Moderators: XnTriq, xnview
Post by helmut » Thu Oct 01, 2009 9:37 pm
@XnView Translators:
This topic is intended for the XnView translators. Please report strings that cannot be translated because there is no string literal in the header files available, here.
@All:
If you happen to find a string that has not been translated, yet, and is not listed here, please report it in the appropriate topic for your specific language.
'"Acquire returned false'
Post by helmut » Thu Oct 01, 2009 9:39 pm
When experience scanning problems, XnView displays the error message "Acquire returned false". This message might be returned by the Twain Driver, but XnView should translate it, whenever this exactly message is thrown. Other message (are there any) might be just passed through and displayed.
Dreamer
Re: 1.97 English Translation / List of new strings
Post by Dreamer » Sat Nov 07, 2009 2:01 am
There is a new option in beta 2, in Slide show dialog, "More options":
"'Add folder' add its subfolders"
How to translate it??
Dreamer
Post by xnview » Sat Nov 07, 2009 12:32 pm
Dreamer wrote:How to translate it??
Right, new sentences in B2:
#define TXT_Add_Folder_Recurse							"'Add folder' add its subfolders"
#define TXT_TemplateMenu_Size_Bytes					"Size (Bytes)"
Post by helmut » Mon Nov 09, 2009 11:36 am
When using "Edit > Meta data > Edit GPS data..." without having installed exiftool, an error message "Please install EXIF tool in AddOn folder". From what I can see this string is not translatable ATM. Pierre?
Post by xnview » Mon Nov 09, 2009 1:40 pm
helmut wrote:When using "Edit > Meta data > Edit GPS data..." without having installed exiftool, an error message "Please install EXIF tool in AddOn folder". From what I can see this string is not translatable ATM. Pierre?
Right,
#define TXT_String_Install_Exiftool					"Please install exiftool in AddOn folder"
added
Re: Non-Translatable strings [All languages]
Post by helmut » Mon May 03, 2010 8:31 pm
Is there a way to translate the strings that are displayed in the ImageShack plugin for XnView (Windows)?
E.g. "Do you want to upload your files on the public server ImageShack?"
Post by xnview » Tue May 04, 2010 8:49 am
helmut wrote:Is there a way to translate the strings that are displayed in the ImageShack plugin for XnView (Windows)?
You have the .lng file
Post by helmut » Tue May 04, 2010 9:00 pm
Right, there's Paint.lng and NeroCD.lng. But after installing the ImageShack plugin there's no IShack.lng (or similar). So what do I do?
Post by xnview » Thu May 06, 2010 11:52 am
You have no ImageShack.lng??
Post by helmut » Thu May 06, 2010 7:52 pm
xnview wrote:You have no ImageShack.lng??
No, there's no such file included in the ZIP archive. I've downloaded the ImageShack plugin <here>.
Post by xnview » Mon May 10, 2010 7:42 am
Please check in the Plugin package...
Post by helmut » Thu May 13, 2010 7:11 am
ImageShack download is listed in ** AddOns ***. Which Plugin file should I download? And why? I really think and expect that when downloading an Add on (e.g. ImageShack PlugIn) the appropriate language file must be included. Or what's the logic behind this?
Post by xnview » Mon May 17, 2010 7:47 am
helmut wrote:ImageShack download is listed in ** AddOns ***. Which Plugin file should I download? And why? I really think and expect that when downloading an Add on (e.g. ImageShack PlugIn) the appropriate language file must be included. Or what's the logic behind this?
The full plugin file, i'll remove other links...
Post by helmut » Tue May 18, 2010 7:06 am
I couldn't find the full plug-in file on the download pages. Could you please provide a link to the appropriate download page or a direct link?
