Can I remove black border in presentations?
Pasint
Post by Pasint »
A thick black border appears in all presentations though I actually want to removed in EXE files with presentations on a HD TV.
I see that the border appears on the TV and on the computer screen too.
When I click on the full screen icon for particular pictures and browse full screen the screen is filled so this border appears in EXE/SRC files.
I tried unchecking the USE FRAME option in the MORE OPTIOND tab.
I have tested powerpoint full photo presentations and other types of slides and they fill the whole screen. I have the full screen option checked but also tried a 1024x768 fixed size too.
Is there a way to get rid of the black frame/border? Is this a bug?
Thanks
Re: Can I remove black border in presentations?
Your picture are in 1024x768 or with same ratio?
beepboop
Post by beepboop »
I had this problem too. I had to make the changes, leave the menu, go back into settings and just click OK again (without making any changes). Then I logged out and back in again and since then the borders around fullscreen images are gone and my other options stick as well.
