XnView v1.80 RC1 est disponible ici : http://www.xnview.com/beta/XnView-RC1.zip
Si vous trouvez des bugs, merci de me contacter.
Added : binary without dithering
Added : Goto page dialog with update
Added : Automatic levels & contrast
Added : Load all pages in multi file create
Added : Edit Tiff Multipage
Added : New options in Batch scan
Added : Support of WPG 5.1 & 6.0
Added : Pause key to start/stop automatic slideshow
Added : Keep date/time for IPTC
Added : MSBF option for DPX
Added : Option to start slideshow/convert with files from folder
Added : Replace/Options in Batch rename
Added : Camera options in NConvert
Added : JPEG Embedded thumbnail
Added : Thumbnail in batch rename
Added : History & Use last used template option in batch rename
Added : PS/AI/PDF thumbnail option
Added : FLI/FLC as animation
Added : multi ICO writing
Added : Custom date format
Added : HTML template
Added : IPTC searching
Added : EXE/SCR slideshow (windows only)
Added : Zoom with wheel mouse
Added : Opacity in "Add text"
Added : PSD writing
Added : Options for page extract
Added : Popup menu on folder view (rename, delete, create folder)
Added : Start slideshow (recurse or not) from a folder
Added : High quality, transitions in slideshow
Added : One strip for TIFF saving
Added : User config for infos displayed below thumbnails
Added : Support of CGM/SVG from CadSoftTools
Added : WIA support
Added : Thumbnail for .htm/.html
Added : Plugin for AWD (windows only)
Added : Thumbnail for quicktime movie
Added : Lossless rotation is applied to the thumbnail too, if present
Added : New Layout (Filmstrip mode)
Added : DDS writing
Added : Use external player for movie
Added : Crayola ART read support
Added : Folder can be Copied/Moved
Added : 3D border & Drop shadow in Effect
Changed : Options
Changed : Browser & view mode has own size/position
Changed : Wallpaper in "Application Data" instead of "My Documents"
Changed : Use of DEL key in view mode
Changed : Selection in browser with Shift
Changed : Canvas resize in NConvert (added position)
Changed : Camera RAW
Changed : LIBPNG 1.2.8
Changed : Timer value in slideshow can be entered like 0.5
Changed : User Plugins are now in Plugins folder with extension .usr
Changed : Multipage Create, edit & extract in tools menu
Changed : New method to send picture in Total Commander
Improved : xnview.ini reading/writing
Improved : HTML create
Improved : Batch rename
Improved : Adjust dialog
Improved : Adjust HLS dialog
Improved : Global filter dialog
Improved : Generate file listing
Improved : Copy/Move to dialog (windows only)
Improved : Plugins cache to speedup startup
Improved : IPTC dialog
Improved : View in fullscreen from browser (option: enter for fullscreen)
Fixed : Video thumbnail
Fixed : ICL
Fixed : empty descript.ion created
Fixed : DPI options for PDF are not used in Multi-Page create
Fixed : BMP
Fixed : Save as & Prev/Next file
Fixed : IPTC
Fixed : Vicar
Fixed : Psion Bitmap 3 grey
Fixed : XPM export
Fixed : disable directory view
Fixed : Problem with font & '&'
Fixed : DDS
Fixed : PSP
Fixed : KQP
Fixed : TGA
Fixed : Associations on Xp (windows only)
Fixed : IPTC writing dialog
Fixed : View IPTC Custom tag
Fixed : EXIF Casio Makernotes
Fixed : DDS D3DFMT_P8
Fixed : CRW/NEF/ORF/...
Fixed : Many other things...
XnView 1.80 Release Candidate 1 (Windows)
Tests version 1.80 RC1
Je viens de commencer à tester cette version qui apparemment apporte
plein de petits plus trés interessant.
j'ai néanmoins rencontré quelques anomalies que je signale ici :
- les données IPTC et EXIF ne sont pas affichées dans les thumbnails
- plantage en mode vue en passant à l'image suivante
- description (CTRL D) inopérante sur plusieurs images
- l'annotation ne s'affiche dans la page web
Et quelques questions :
- à quoi sert le COMMENT d'une image. J'en ai saisi un et il n'apparait pas en colonne en mode détail
- peut-on recadrer une iamge et si oui peut-on garder un ratio (ex numérique 4/3)
Merci pour les infos et encore bravo pour les améliorations de ce produit déjà trés puissant.
A ce sujet, j'ai téléchargé la version d'essai deluxe car j'hésite toujours à l'acheter. J'hésite de plus en plus car certaines fonctions de la 1.80 sont maintenant plus puissante que la "deluxe" (ex: génération liste des fichiers paramétrable...). Les améliorations de la version gratuite sont-elles en générale répercutée sur la version payante ?
A+
A+
Re: Tests version 1.80 RC1
Bug corrigé dans la RC2patsarzi wrote:j'ai néanmoins rencontré quelques anomalies que je signale ici :
il me faudrait plus d'infos sur comment cela plante?- plantage en mode vue en passant à l'image suivante
Toujours les memes?- description (CTRL D) inopérante sur plusieurs images
Ok, je corrigerais.- l'annotation ne s'affiche dans la page web
Certains fichiers possedent un champ COMMENTAIRE- à quoi sert le COMMENT d'une image. J'en ai saisi un et il n'apparait pas en colonne en mode détail
Oui chargez l'image, puis Edit/Selection ratio- peut-on recadrer une iamge et si oui peut-on garder un ratio (ex numérique 4/3)
OuiA ce sujet, j'ai téléchargé la version d'essai deluxe car j'hésite toujours à l'acheter. J'hésite de plus en plus car certaines fonctions de la 1.80 sont maintenant plus puissante que la "deluxe" (ex: génération liste des fichiers paramétrable...). Les améliorations de la version gratuite sont-elles en générale répercutée sur la version payante ?
