Default toolbar icons demopage
mezich
Re: Default toolbar icons demopage
Post by mezich »
budz45 wrote:Next thing I await in future is an icon for "Theme" and then second thing to re-think/recolor the view mode icons
I'm not plain to make "Theme" icon because this function is not often used.
Icons for View mode, by my opinion, should differ from other. May be b/w and without rectangle.
budz45
Post by budz45 »
mezich wrote: I'm not plain to make "Theme" icon because this function is not often used.
OK, "theme" not required then :)
and by 'view mode icons' I am meaning these blue-ish ones that Xntriq was writing about earlier:
XnTriq wrote:
  • Image
Are they for 'view mode' or for 'browser mode' or intended for something else?
Thank you for great work.
JohnFredC
Post by JohnFredC »
2mezich
Please don't change the icons that budz45 has marked through (see previous post). They are the most succinct and clear of all!
John
budz45
Post by budz45 »
Well actually John, I've just discovered that those icons are mostly intended for the 'Browser' mode (so it seems) and not so much the viewer, so yeah I dont mind so much there. I still reckon the blue-ish color could be lightened somewhat (mezich suggested 'white') to a lighter gradient color.
But yes, can see now that they were intended to be placed in the 'Browser' menus:
Image Image Image
mezich
Post by mezich »
budz45 wrote:(mezich suggested 'white')
b/w = black & white. That means blue should be changed to black
budz45
Post by budz45 »
mezich wrote: b/w = black & white. That means blue should be changed to black
Ok, would be interested to see the b/w you create of those :)
...Could you also update the Demopage with the 2x lovely new icons please http://newsgroup.xnview.com/viewtopic.p ... 55#p100014
mezich
Post by mezich »
budz45 wrote:...Could you also update the Demopage with the 2x lovely new icons please http://newsgroup.xnview.com/viewtopic.p ... 55#p100014
I'm not at home.
budz45
Post by budz45 »
mezich wrote:I'm not at home.
Oh, I apologize...Well anyway I kindly asked Pierre to use the same png's you posted; http://newsgroup.xnview.com/viewtopic.p ... 55#p100014 - Since next XnView MP version is not too far away and any new icons not on Demopage/zip might get overlooked :P Thank you mezich for the great designs.
budz45
Post by budz45 »
Hi mezich,
Thanks for recent Demopage update.
Right,
please look at this picture:
in the picture I have made 2 changes:
1.) The "Fullscreen" icon uses a lighter pale blue shade inside - looks better, more modern :)
2.) The "Properties" icon is now a few pixels taller at the top, so to reach the max 24x24 bounding pixel size
I hope you agree and can update these two icons like the way I did above in my example.
mezich
Post by mezich »
budz45 wrote: 1.) The "Fullscreen" icon uses a lighter pale blue shade inside - looks better, more modern :)
Hm. I'm not sure. Current version more contrast.
budz45 wrote:2.) The "Properties" icon is now a few pixels taller at the top, so to reach the max 24x24 bounding pixel size
Why it should reach max bounding? Icons alligned by baseline. Tomorrow will check position.
Moderator & Librarian
XnTriq (XnConvert » [url=http://newsgroup.xnview.com/viewtopic.php?p=106249#p106249]Actions menu[/url]) wrote:
xnview wrote:Do you have idea for icons? (Image/Map/Filter/Misc) to help yuri
Those are really tricky :|
  • Image
    • Add mask, Automatic crop, Canvas resize, Change color depth, Clean metadata, Crop, Extract channel, ICC convert, IPTC/XMP, Mirror, Replace Color, Resize, Rotate, Set DPI, Text, Vignetting, Watermark
    Map: brightness + contrast or palette/colormap
    • Adjust, Align histogram, Automatic contrast, Automatic levels, Color balance, Conbright, Equalize, Exposure, Gammasat, HLS (Hue/Lightness/Saturation), Levels, Logarithmic Lut, Negative, Normalize, Normalize Ex, Posterize, Saturation, Sepia, Shadow-Highlight, Solarize, Swap component, Temparature
    Filter
    • Average, Blur, Edge detect, Emboss, Emboss more, Enhance detail, Enhance edges, Enhance focus, Focus restoration, Gaussian blur, Maximum, Median box, Median cross, Minimum, Reduce noise, Sharpen, Soften
    Misc: function(x) in algorithm or effects (FX) or magic wand or bag of tricks
    • Add noise, Bloom, Border, Border 3D, Crystalize, De-interlace, Fantasy, Halftone, Lens, Mosaic, Oil painting, Oil painting 2, Old camera, Photo Spread, Pointilite, Retro, Shear, Slice, Spread, Swirl, Symmetry, Tile, Waves
  • Image
budz45
Post by budz45 »
Hi mezich,
Do you have a 48x and 32x size of the standard 'picture' metaphor...
....Reason is I want to make something for Pierre concerning this topic: http://newsgroup.xnview.com/viewtopic.php?f=34&t=21878
