Default toolbar icons demopage
All icons I made for XnView - http://www.mezich.ru/xnview/demo/
With time I will add more icons.
Now I'm working with Change timestamp metaphor (cmd_SetTimeStamp)
What do you think? Let me know your ideas for this metaphor.
Re: default toolbar icons demopage
Thank you for your effort in the Mezich toolbar, it looks really great!
Your demo page looks very good, very well done!
== Some feedback regarding your current designs:
It's very hard to say which drafts to use for cmd_SetTimeStamp and cmdSetComment.
For cmd_SetTimeStamp I prefer #2 a bit (the stamp in #1 reminds me of a joystick).
For cmd_SetComment I think #2 is good. It looks a bit like "Rename file" in the small toolbar (Main 16x16) but both position and design makes it still easy enough to distinguish. The comment "bubble" looks very much like the bubble used in "Show information". perhaps the comment bubble could be light-yellow to differentiate comment from information (light-yellow is used in some programs for displaying comments, e.g. Excel).
Thanks for your comment Helmut.helmut wrote:Thank you for your effort in the Mezich toolbar, it looks really great!
Demopage show how icons will looks in toolbar. Also all graphics stored in one place for easy update. Whould be nice if Pierre for next release will use icons from demopage.
cmd_SetTimeStamp - I like metaphor in #1 (clock stamped on file) but don't know how make stamp better. May be stamp handle shold be wooden.
As I understand cmd_SetComment will add text user can see with cmd_ShowInfo(Show information). That's because icons looks similar. So I don't sure about light-yellow background.
Perhaps you point Pierre to your webpage or this topic via email.mezich wrote:.. Whould be nice if Pierre for next release will use icons from demopage.
Yes, a wooden or "single" colour stamp might be better.mezich wrote:cmd_SetTimeStamp - I like metaphor in #1 (clock stamped on file) but don't know how make stamp better. May be stamp handle shold be wooden.
The comment can be used in "Show information" but it is not necessarily shown because "Show information" can be customized. The comment is just one of various image information that can be used and displayed with "Show information".mezich wrote:As I understand cmd_SetComment will add text user can see with cmd_ShowInfo(Show information). That's because icons looks similar. So I don't sure about light-yellow background.
Re: Default toolbar icons demopage
Sorry, I didn't have time to respond about these before now, but unfortunately, neither example works for me.
cmd_SetTimeStamp
The "stamp" shown in Example 1 implies "watermark" or "cancel" or "approve" ... but nothing to suggest time. The clock in Example 2 does suggest time, but there is no visual implication of an action to set or change that time.
IMO a combination of document symbol (for context), clock symbol (for item to be changed) , and pencil (for the change action itself) would be better:
cmd_SetComment
Example 1 suggests "display commandline" or "run DOS". Example 2 is very confusing... the pencil suggests "change" but the CRT suggests "run DOS". What would that mean? Example 3 dispenses with "CRT" metaphor, but lacks an action symbol.
I like the balloon shape though. In the social internet world, a comment is frequently symbolized by a "balloon".
Perhaps...
OK. There's my 2 cents worth.
cmd_SetTimeStamp
- pencil + document + clock=change document time
cmd_SetComment
Perhaps...
- Pencil + 3 lines in balloon + balloon = edit comment
John
cmd_SetTimeStamp3 added - http://www.mezich.ru/xnview/demo/helmut wrote:Yes, a wooden or "single" colour stamp might be better.mezich wrote:cmd_SetTimeStamp - I like metaphor in #1 (clock stamped on file) but don't know how make stamp better. May be stamp handle shold be wooden.
what do you think?
Clock implies clock. Not a watermarkJohnFredC wrote: cmd_SetTimeStamp
pencil + document + clockJohnFredC wrote: IMO a combination of document symbol (for context), clock symbol (for item to be changed) , and pencil (for the change action itself) would be better:
hmm. In this combination I'm nor sure that pencil related to clock.
cmd_SetTimeStamp4 added - http://www.mezich.ru/xnview/demo/JohnFredC wrote: A calender symbol might work well in place of the clock.
It's what you meant?
In #1 and #2 - used input text field = you can enter some text. In combination with baloon = enter comment.JohnFredC wrote: cmd_SetComment
Perhaps...
What is CRT?
Thanks for you centsJohnFredC wrote:OK. There's my 2 cents worth.
cmd_SetComment4 added
cmd_SetTimeStamp
cmd_SetComment
My approach to icongraphy is to start with a symbol rebus (pencil + document + clock = change document time) and then try to simplify it by searching for symbols that combine two or more components into one symbol.
Am in total agreement that a pencil on every toobar icon that represented "change" this or that would look foolish, but one has to start somewhere..
Generally, a pencil symbol in an icon implies "write" or "change".mezich wrote:pencil + document + clock
No. Those look like the rating bullets, not a calendar. I meant a "tear off" one-day-per-page calendar symbol. That is also relatively standard icongraphy for date and sometimes date/time.JohnFredC wrote: A calender symbol might work well in place of the clock.mezich wrote:cmd_SetTimeStamp4 added - http://www.mezich.ru/xnview/demo/
cmd_SetComment
CRT = Cathode Ray Tube = Display monitor. The rectangle w/rounded corners scribed inside the comment balloon in Examples 1 & 2 looks like a computer monitor with a cursor suggesting the DOS command-line. That is a visual association which is very difficult for old-timers such as myself to shake.What is CRT?
John
cmd_SetTimeStamp
Screwdriver or wrench better for "change" in this context. What do you think?
cmd_SetComment
For me command line should looks like ">C:_" or ">_" on black background.
Demopage updated.
For me, basic meaning of pencil symbol is "write".JohnFredC wrote:Generally, a pencil symbol in an icon implies "write" or "change".mezich wrote:pencil + document + clock
I think this metaphor is deadlock direction because not related to file and not clear to understand - too many meanings.JohnFredC wrote: A calender symbol might work well in place of the clock.No. Those look like the rating bullets, not a calendar. I meant a "tear off" one-day-per-page calendar symbol. That is also relatively standard icongraphy for date and sometimes date/time.mezich wrote:cmd_SetTimeStamp4 added - http://www.mezich.ru/xnview/demo/
cmd_SetComment
I'm surprises that in shape of baloon with input field you see something like monitor.JohnFredC wrote: CRT = Cathode Ray Tube = Display monitor. The rectangle w/rounded corners scribed inside the comment balloon in Examples 1 & 2 looks like a computer monitor with a cursor suggesting the DOS command-line. That is a visual association which is very difficult for old-timers such as myself to shake.
That's because I suggest use screwdriver or wrench.JohnFredC wrote: My approach to icongraphy is to start with a symbol rebus (pencil + document + clock = change document time) and then try to simplify it by searching for symbols that combine two or more components into one symbol.
Demopage updated.
For cmd_SetTimeStamp, I like #4 best, even though I myself suggested the screwdriver symbol be added.
BTW, what does the "L" in the blue dot (Examples 1 & 3) mean?
For cmd_SetComment, I am still uncertain. The pencil (or wrench) communicates strongly "change", but it looks peculiar. And the comment balloon by itself (esp. the one in Example 4) suggests "chat"...
Please, someone else jump in here. As always, this is difficult, especially cross-culturally.
John
Minute and hour hand on stamped clock.JohnFredC wrote:BTW, what does the "L" in the blue dot (Examples 1 & 3) mean?
That explains why I didn't understand those examples.Minute and hour hand on stamped clock.
I think there is a "loose" convention to choose a symbolic time that cannot be confused for an alphanumeric. Examples would be: 9:55 or 2:05 or 3:25 or 5:40, etc.
There is a similar convention in watch/clock advertising.
John
I think #3 easier to remember and use than #7 because it's more expressive.JohnFredC wrote:That explains why I didn;t understand those examples.Minute and hour hand on stamped clock.
I personally like the cmd_SetTimeStamp #3 and cmd_SetComment #1 icons.
In general I like all the new and modified icons. cmd_Capture now has a recognizable application window on the backroung. I constantly mix Capture to Acquire so it is much better now.
The only icon I think is a little off is cmd_BatchRename. Symbolism in cmd_BatchRename is berfect, but the icon looks silly with the small file icons. I would suggest either make the files bigger and overlapping or different design with three overlapping 'rename boxes'.
I also would suggest changing the '?' symbol in cmd_About to 'i'. New cmd_Help looks too similar and even before this I have clicked few times the 'About' button when I wanted to open the help.
