Add skins (XP, Vista, Mac skins) to menu
erdinc
Post by erdinc »
1. Can you please add skins to the menu where I can change it with a click of a button, just like it is in faststone image viewer? Please have a look to Faststone Image Viewer. Under settings/skins menu they have skins for win XP, Vista and Mac.
The program comes with 10 different skins build in. It was my favorite viewer before I discovered Xnview. Xnview handles video files/thumbnails much better and you can change the layout. But please add an xp skin to menu.
2. In faststone image viewer when you right click any image the right click menu gives you the option to "open containing folder".
Can you please add the "open containing forder" option to right click menu?
Thanks
Erdinç
Re: Add skins (XP, Vista, Mac skins) to menu
erdinc wrote: 1. Can you please add skins to the menu where I can change it with a click of a button, just like it is in faststone image viewer? Please have a look to Faststone Image Viewer. Under settings/skins menu they have skins for win XP, Vista and Mac.
There is no skin in xnview
To open the folder in windows explorer?
