HP Ipaq314 WIN CE 5.0 Install problem
Discussions on XnView for PocketPC
helifan
Post by helifan »
Great product!
Got it installed and running w/o any problem on my HP Rx5935 via Activsync.
On my Ipaq314 I installed it using CAB file.
Installation itself went OK.
Attempting to launch XNPOCKET (or SLIDE) always returns following error message:
Cannot find " Xnpocket" (or one of its components) Make sure path and filename are correct...etc etc.
In the "Program Files\Xnview Pocket" directory following files are found:
XNPOCKET.EXE
SLIDE.EXE
FMODE.DLL
15 language files
Clicking on the icon found in the installation directory does not help either.
Thanks
Re: HP Ipaq314 WIN CE 5.0 Install problem
Strange, do you have problem with other software too? Like Totalcommander?
helifan
Post by helifan »
Just tried with TOTALCOMMANDER.
Exactly the same problem!
Strange...
(I do not use any other software using CAB to install)
And if you extract cab on a PC, and transfer the files?
helifan
Post by helifan »
Well... How should I do this on a PC?
Do I need any additional software?
I am currently running XP Pro
Thanks
helifan wrote:Well... How should I do this on a PC?
Thanks
You can extract the cab with an archiver software
helifan
Post by helifan »
I did that already (using Alzip)but:
- no executable file or install_file is extracted on PC.
- transfer of extracted files on the PNA went OK
- But I do not find a way to install it
Extracted file xnpocket.oo1 (size 1.23 MB)
I know this probably not the right place for this topic, but I am lost...
Thanks
Right the cab can't be extracted correctly. Please send me your email by PM
helifan
Post by helifan »
Received, unziped and transfered the files onto newly created directory on the SD card.
Thanks!
Unfortunatly, Ipaq 314 reacts exactly as previously, namely returns the same error message. (see previous post)
It sounds hopeless or do you have any further idea?
helifan wrote: It sounds hopeless or do you have any further idea?
No :-(
