Large Files 1.31 problem
Discussions on XnView for PocketPC
AJ
Post by AJ »
When I open a large (8megapixel Canon 1d MK II) file off the CF card in XnView Pocket, I can not crop it or save tone changes.
I hit crop and nothing happens. With smaller files it works fine. There is plenty of space in the saving location.
This is on an Axim 50v.
So I am guessing there is a file size limit, what is it?
The other things I noticed is when I save an IPTC "template" it looks like it only saves the caption info and not the rest of the fields.
Re: Large Files 1.31 problem
AJ wrote:When I open a large (8megapixel Canon 1d MK II) file off the CF card in XnView Pocket, I can not crop it or save tone changes.
On main memory, do you have enough space?
I'll check
AJ Mast
1.31 larg files
Post by AJ Mast »
xnview wrote:On main memory, do you have enough space?
I have 2x more space than the file size. I also noticed it gives very small thumbnails, say in the crop screen for these files.
Re: 1.31 larg files
AJ Mast wrote:On main memory, do you have enough space?
I have 2x more space then the file size. I slo noticed it gives very small thumbnails, say in the crop screen for these files.
very small thumbnails?? How many memory do you have? Which size in pixels of your picture?
AJ Mast
Post by AJ Mast »
The pictures are 3504 x 2336 pixels. (5.76mb)
The Unit has 128mb ROM and 64mb of RAM.
AJ Mast wrote:The pictures are 3504 x 2336 pixels. (5.76mb)
For viewing an image file, it is read into memory and uncompressed. In your case your 5.76 MB image file will uncompress to:
3504 x 2336 Pixel x 3 Byte (RGB colour) = 24.556.032 Bytes (~24 MB). So this should fit into your 64 MB RAM.
Do you have other applications running? What's your free memory size (before starting XnView Pocket)?
