Problem with password at ftp-addon 1.04
Plug-ins, add-ons, skins, icons, templates and other downloads. Contributions are welcome.
Moderators: XnTriq, xnview
hawk_vs
Post by hawk_vs » Tue Apr 21, 2009 4:41 pm
Hello ,
We use the xnview complete version 1.96 with only ftp-addon 1.04 in german language .
a fresh installation of windows xp prof sp3 and xnview ,xnview can't save the password for ftp-transfer in the xftp.ini at Users-home/Anwendungsdaten/Xnview/ .
The User ist the local-Admin of the fresh PC .
The FTP-Transfer at self is functional,but the password is every time away.
On other PC, xnview can save the Passord for ftp-transfer in xftp.ini-File also at USERS-Home/Anwendungsdaten/Xnview/
On both PC was xnview installed with the same installation-method.
Use xnview other programm to save the key at the xftp.ini file ,which are not delivered with standart Win-xp-Professional ?
Thanks for Reply
ckv
Re: Problem with password at ftp-addon 1.04
Post by ckv » Tue Apr 21, 2009 5:00 pm
I vaguely remember that someone requested not to save password in the ini, because password were stored as plain text... Or was this with some other project?? :)
hawk_vs
Post by hawk_vs » Tue Apr 21, 2009 5:06 pm
no the password,was save as a hash in the xftp.ini.
also whe we copied the ini.file to the fresh pc , xnview not using the passord-hash.
any other suggestions or solutions ?
Post by xnview » Wed Apr 22, 2009 7:46 am
hawk_vs wrote:no the password,was save as a hash in the xftp.ini.
You have copied the .ini in the same folder? XnView use same ini settings?
hawk_vs
Post by hawk_vs » Wed Apr 22, 2009 8:29 pm
hi xnview ,
yes weve copied the xftp.ini in the same location of the fresh installed PC ,but the xnview on this Machine doesn't use the hashed password of the ini-file or save a new one.
Weve tried also the Portable -Version of xnview . The Same Problem.
We patched + reinstalled the fresh PC, nothing will happen . :x
Thanks for Reply
Post by xnview » Thu Apr 23, 2009 9:30 am
Ok, i've tried and right there is a problem. I use the windows api and it seems that there is a problem, i don't know why. I must change the crypt function...
hawk_vs
Post by hawk_vs » Thu Apr 30, 2009 10:21 am
Hello xnview,
when or where is the new version of the plugin ready to download ?
thanks for reply
Post by xnview » Mon May 04, 2009 6:40 am
hawk_vs wrote: when or where is the new version of the plugin ready to download ?
I don't know, i'll try to do that with next release
Post by xnview » Tue May 05, 2009 1:46 pm
Could you send me your email by PM?
