Automatically recreate the thumbnail after lossless crop
Dreamer
Post by Dreamer »
Automatically recreate the thumbnail after lossless crop, not only after lossless rotate.
Thanks.
Dreamer
Re: Automatically recreate the thumbnail after lossless crop
+1
Not updating the thumbnail might be even embarrassing depending on the stuff that was cut off. An example: http://graphicssoft.about.com/b/2003/07 ... -blame.htm
jaqian
Post by jaqian »
+2
Also an option to rotate thumnail so that it matches the full image, currently I have to edit in GIMP and save thumbnail.
Sony Alpha α100 (Silver)
Linux Mint 7
GeorgD
Post by GeorgD »
+3. I often forget it and later wonder that I did not yet process the pics of the folder but it's only the preview that's old...
jaqian wrote:Also an option to rotate thumnail so that it matches the full image, currently I have to edit in GIMP and save thumbnail.
Sorry, I don't get this - what do you mean? What's different to XnView's build-in function (go to browser, select all JPG and Edit - Metadata - Recreate Thumbnail)?
In the XnView Wiki, you can improve the user guide / documentation / F1-help for XnView (classic/Windows) and for XnViewMP
Dreamer
Post by Dreamer »
You are right, actually embedded thumbnails are rotated automatically when using lossless rotate in browser here - not like lossless crop! So even recreating the thumbnail is not needed in that case.
Dreamer
Dreamer
Post by Dreamer »
Should be added/changed in 1.97 beta 1, but...
...Embedded thumbnail is not recreated? :?
Moved to "1.97 Testing - Feedback".
Dreamer
Dreamer wrote:Should be added/changed in 1.97 beta 1, but...
For me, the embedded thumbnail is re-created...
Dreamer
Post by Dreamer »
xnview wrote:For me, the embedded thumbnail is re-created...
Automatically, after lossless crop??
Dreamer
Yes, i've checked again
Dreamer
Post by Dreamer »
Strange, I tried with cache enabled and disabled, manually rebuild thumbnails... Still the same. When using non-lossless crop, it's OK.
Anyone else? :?
Dreamer
Dreamer wrote:Strange, I tried with cache enabled and disabled, manually rebuild thumbnails... Still the same. When using non-lossless crop, it's OK.
Anyone else? :?
Could you send me a jpeg sample?
GeorgD
Post by GeorgD »
Update: Yes, I do have similar issues as Dreamer :-( Cropping once does all the job, then again updates only EXIF thumbails but keeps old XnView-Cache-Thumbnail, then again updates XnView-Cache-Thumbnail but not the EXIF-thumbnail. It's the same image (I made some clones) so the image content can't be the reason. I can't find a rule for the behaviour. It happens with shortcut nd Menu entry, "Backup option for lossless operation" enabled or disabled.
Dreamer
Post by Dreamer »
OK, so it looks, it works always one step behind.
- original image is 1600x1600 (just for example)
- lossless crop to 800x800
= embedded thumbnail is the same as 1600x1600
- now crop it again to 400x400
= embedded thumbnail is now the same as 800x800 image
- crop it again to 200x200
= embedded thumbnail is the same as 400x400 image
Tested with cache disabled in beta 2, on Win Vista.
Dreamer
marsh
Post by marsh »
Dreamer wrote:OK, so it looks, it works always one step behind.
It works fine here. Some kind of read ahead/cache behind issue?
---edit--
Doh! Dreamer's example confirmed with write>jpg 'rebuild thumb' setting on or off.
Could you send me jpeg sample?
And 'rebuild EXIF thumbnail' works?
