I cant see directory in thumbnail labels
ikutluay
Post by ikutluay »
Hello. I have a zillion pictures in a folder. and i want to delete some pics faster. IM using show all files recursive. At this screen i want to see folder of pictures. I can setup this easyl in tooltips and it is working. But i cannnot achieve this in thumbnail labels. After using custom 2 and select folder name or directory it is craching. Im manually add this option in ini file. Then it is still dont show the folder. It is showing on full screen but i need this in thumbnail preview.
Also i think add "show full path in sttus bar" check box option will be very good.
regards
Re: I cant see directory in thumbnail labels
Yes right a problem
