I experience very frequent crashes with the B3 version of 1.96
, 1 out of 5 or 10 times, XnView crashes, on a Vista 64 system, and also on a 32 bit XP system:
The Vista crash reports some extra information:
Problem signature:
Problem Event Name: APPCRASH
Application Name: xnview.exe
Application Version: 1.96.0.0
Application Timestamp: 497ecad2
Fault Module Name: xnview.exe
Fault Module Version: 1.96.0.0
Fault Module Timestamp: 497ecad2
Exception Code: c0000005
Exception Offset: 001b5635
OS Version: 6.0.6001.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 53b1
Additional Information 2: 41a40ebc645c403f68c3180db04ff84b
Additional Information 3: 2703
Additional Information 4: 7749fbd2f7ae84beac33e8e5dccb4095
Restarting xnview and selecting the crop area again works most of the time.
I only experience these crashes when cropping 8-bit greyscale images, but that might be a coincidence.
René
B3: frequent crashes when cropping image
Re: B3: frequent crashes when cropping image
lossless crop? Crash occurs after crop?
No problem in 1.95?
No problem in 1.95?
Pierre ,
are you referring to the caching option being lossless,
if not I am not sure what you mean by "lossless crop".
The crash always occurs right after choosing the crop option from the menu. The selection has already been made.
Regarding the behaviour on the 1.95 version,
I have to look into that.
regards ,
René
regards ,
René
