Rename is working in browser, but some shortcuts don't work good if rename is activated. To reproduce select a file and press F2. Now press one of these keys: Home, End, Delete. Rename is deactivated and the standard functions of those keys are performed, for example: Delete will delete the current item instead of delete a letter. BTW if Delete key is used, rename is not deactivated. Left and right keys are working good.
Also the other keys are not working good - Tab, PageUp/Down, F11...
And the GPF.
- select a folder
- press F2
- press Numpad - or +
= crash
There are probably more issues because the shortcuts are not in the rename mode, but I think it's the same bug, so all these problems might be solved at once.
XnView MP v0.12, Windows Vista SP1, 32 bit.
[FIXED] v0.12 Win32 - Rename - shortcuts are not working g
