XnView 1.96 beta 3
Feedback and Comments on the new 1.96 Test version on Windows.
XnView 1.96 beta 3
XnView 1.96 beta 3 can be downloaded here
Please make a new post for bugs...
These bugs are fixed too:
* Reopen not enabled - http://newsgroup.xnview.com/viewtopic.php?t=16853
* 'Set wallpaper' shortcuts - http://newsgroup.xnview.com/viewtopic.php?t=16844
* conbright & gammasat doesn't work with 32bits - http://newsgroup.xnview.com/viewtopic.php?t=16843
* <Filename number> crash - http://newsgroup.xnview.com/viewtopic.php?t=16818
* Multi scan - http://newsgroup.xnview.com/viewtopic.php?t=16503
* Select all sub categories - http://newsgroup.xnview.com/viewtopic.php?t=16838
* Text position in slide.exe - http://newsgroup.xnview.com/viewtopic.php?t=16856
* Slide size of window - http://newsgroup.xnview.com/viewtopic.php?t=16855
* Wrong size restoration - http://newsgroup.xnview.com/viewtopic.php?p=71085
* Hidden settings - http://newsgroup.xnview.com/viewtopic.php?p=71093
* Grid settings - http://newsgroup.xnview.com/viewtopic.php?t=16866
* Sort filename - http://newsgroup.xnview.com/viewtopic.php?t=16862
* Folder with '.' renaming - http://newsgroup.xnview.com/viewtopic.php?p=71201
* 'set iptc', 'change timestamp', ... stop after some files - http://newsgroup.xnview.com/viewtopic.php?p=71252
* DB cache & folder name with ' - http://newsgroup.xnview.com/viewtopic.php?t=16894
Re: XnView 1.96 beta 3
Please make test on iptc editing, change timestamp, set embedded comment. I have changed some code here...
ckit
Post by ckit »
Thanks, Pierre!
I just had a quick toy with Changing Timestamps and it seems to work fine for me.
ckv
Post by ckv »
Thanks, Pierre :D
I noticed that beta3 has the same slide.exe file as beta2, did you forget to update it?
Thanks, Pierre, for the beta 3 with updated German translation. :-)
Koogle
Post by Koogle »
just gonna add that the mousewheel tab switching should also loop around when when it reaches either end of the opened tabs. And also mwheel down/up and the direction of switching is still working in the opposite direction, I dunno maybe you hadn't changed it.
Koogle
Post by Koogle »
Another annoying thing with XnView that I hope would ideally be fixed by now is it resetting the window position when you goto next/prev file.
Its highly annoying when you open an image, move xnview titlebar location, and then change image while in the same xnview instance, and it resets position. There should be an option to have xnview lock and keep its window position, but still open the next file resizing as it would normaly to current desktop res, !even if that means the image goes off the monitor.. afteral I did move the xnview position, another option to center window would be good too.
so to recap, I have by default [fit image to desktop, large only].. but when using mousewheel to flick through even smaller than desktop res images, it shouldn't be reseting them too the center of the desktop if I have moved the xnview window position.
I'm pretty sure this option doesn't exist, and perhaps it has its own thread topic already.. I can't remember :)
oops66
Post by oops66 »
xnview wrote:Please make test on iptc editing, change timestamp, set embedded comment. I have changed some code here...
The only problem I can found for the moment about this is :
The IPTC field (Ctrl+i): "Misc." tab \ "Original transmission reference" is not updated if "Update or Create XMP" is checked.
Thanks for this new beta3 Pierre (especially about the "Quick Slide Show" info text "blinking" problem).
XnViewMP Linux X64 - Debian - X64
B.Douille
Can't download this version
Post by B.Douille »
Hi Pierre the file can't be downloaded, the url is different from the previous beta 1 & 2.
Rgds,
obelisk
Post by obelisk »
zip is missing from link.
is include/exclude cache folder to be implemented for this ver?
its me
Post by its me »
"Another annoying thing with XnView that I hope would ideally be fixed by now is it resetting the window position when you goto next/prev file.
any comment on this
its me wrote:"Another annoying thing with XnView that I hope would ideally be fixed by now is it resetting the window position when you goto next/prev file.
any comment on this
Please post in general section
Locked
