Keep "lock zoom" enabled even after exit?
Feedback and Comments on the new 1.96 Test version on Windows.
Moderator: XnTriq
ghost zero
Post by ghost zero »
How about keep "lock zoom" enabled even after exit?
Might be so
:arrow: ghost zero
:) Hello !
• It must be so, according to the INI entry :
The Manual wrote
Since 1.92.1…
[View]
LockZoomFlag=Flag
Image0 : The zoom locking is kept through the sessions (standard behaviour).
Image1 : The zoom locking is kept during the current session only (like in the old 1.8… versions)
- So, please check which flag is set in your INI…
:mrgreen: VG
ghost zero
using 1.95.4
in my ini, i only see LockZoom= , no LockZoomFlag ... are they the same thing?
Two entries
:arrow: ghost zero
:) Hello !
• They are two different entries, it seems, I've both here :
LockZoom=0
LockZoomFlag=1
- LockZoom=… shows the current status of that command,
while LockZoomFlag=… defines it's behaviour through the sessions…
- So, add it by hand, according to your needs as explained above.
:mrgreen: KR
A good sample for bad and misleading option names. :-|
@Pierre:
Options without GUI are o.k., but it's very important that the naming for these options is meaningful and clear. Please consider this when naming new options.
obelisk
Post by obelisk »
I don't think it keeps after exit now right?
Tho I prefer it that way.
ghost zero
i just tried LockZoomFlag=0 and LockZoomFlag=1 and neither does anything. any ideas?
ckv
Post by ckv »
ghost zero wrote:i just tried LockZoomFlag=0 and LockZoomFlag=1 and neither does anything. any ideas?
Did you add LockZoomFlag in the right section? Also if you are using registry to save settings, you should add the LockZoomFlag in the registry, not in the xnview.ini.
ghost zero
im saving settings in .ini and i added the LockZoomFlag= in the same section as the existing LockZoom=
any ideas?
Read the…famous…Manual
:arrow: ghost zero
:) Hello !
• I tested with :
LockZoomFlag=0, it doesn't work, the locking is not kept at next start.
- Hence, it's broken in 1.96 ß-2 and ß-3 :bugconfirmed:
• Anyway, it's always good to read the header of THIS PARAGRAPH to handle the INI changes correctly…
:mrgreen: KR
ghost zero
so its a bug that needs to be fixed right?
More complicated
:arrow: ghost zero
:) Hello !
• Certainly, I tested again with ß-3 and LockZoomFlag=0: After a second restart, I got a locked zoom, but reverse !
- I mean for instance if closed with 150%, reopen displays at 75%… :|
• I ought test further to define this faulty behaviour precisely (if possible).
:mrgreen: KR
Re: More complicated
Sorry i don't understand the problem.
If you add LockZoomFlag=1, the lock zoom flag is not kept.
Else 'Lock Zoom' will be locked or not following previous session...
I have to correct myself:
A good sample for bad and misleading option names and option values. :-|
(Will not help but I couldn't resist.) :twisted:
ghost zero
if this option doesn't exist, can it be added? so that lock zoom remains checked even after exit?
Locked
