B2 - PNG IPTC dosen't work
Feedback and Comments on the new 1.96 Test version on Windows.
Jaff
Post by Jaff »
Writting IPTC data on PNG files dosen't work. It will give an "Error writing the file <C>"
Imi este indiferent ce cred ceilalti despre mine, caci oricum fiecare crede ce-i convine lui si nu ceea ce e real, doar ca mi-ar fi placut sa ma vada asa cum sint de fapt, nu asa cum poate le-ar placea lor sa creada. Ei au ales deja...
Re: B2 - PNG IPTC dosen't work
Jaff wrote:Writting IPTC data on PNG files dosen't work. It will give an "Error writing the file <C>"
You can only edit IPTC on tiff or jpeg
Jaff
Post by Jaff »
then it should be grayed on menus or on IPTC edit window marked the fields that can be edited and converted to similar TextualData tags on PNG file. See >>> link << for more info and EXIF to PNG draft
Locked
