B2 - JPEG lossless transformation for any kind of files?
Feedback and Comments on the new 1.96 Test version on Windows.
Jaff
Post by Jaff »
JPEG lossless transformation (and submenu) must be disabled (grayed) on right clicking on a non JPEG file in browser mode / also from Tools menu. If selected file is a JPEG then "JPEG loseless transform" should be (and is) available on menus or else.. grayed.
Imi este indiferent ce cred ceilalti despre mine, caci oricum fiecare crede ce-i convine lui si nu ceea ce e real, doar ca mi-ar fi placut sa ma vada asa cum sint de fapt, nu asa cum poate le-ar placea lor sa creada. Ei au ales deja...
Bug in Browser---
:arrow: Jaff
:) Hello !
• It's greyed out in View mode as it should, while it isn't in the Browser ( I mean : the buttons of the tool-bars). :bugconfirmed:
- It's so in old versions too…
:mrgreen: KR
Re: B2 - JPEG lossless transformation for any kind of files?
Jaff wrote:JPEG lossless transformation (and submenu) must be disabled (grayed) on right clicking on a non JPEG file in browser mode / also from Tools menu. If selected file is a JPEG then "JPEG loseless transform" should be (and is) available on menus or else.. grayed.
Right a new little problem
Jaff
Post by Jaff »
Can JPEG lossless transformation menu be grayed too when not available this option (not only submenu of it)? That way you know faster if this action is available or not before exploring the submenu.
Since no option of submenu is available I think it should be grayed too. Thank you!
Locked
