Select any .PNG file / press CTRL+D to describe / be sure to have checked the (embedded comment) box / leave a null comment (0 char$) and press write. Repeat several times. Compare original to new file. For every write of null description xnview add at end of file a $FF byte.
repeated 5 null descriptions = filesize+5 $FF bytes at end of file
[Fixed] B2 - PNG null description add an $FF byte at EOF
Moderator: XnTriq
Imi este indiferent ce cred ceilalti despre mine, caci oricum fiecare crede ce-i convine lui si nu ceea ce e real, doar ca mi-ar fi placut sa ma vada asa cum sint de fapt, nu asa cum poate le-ar placea lor sa creada. Ei au ales deja...
