Select any .PNG file / press CTRL+D to describe / be sure to have checked the (embedded comment) box / leave a null comment (0 char$) and press write.
PNG+HDR+DAT+END ---> PNG+HDR+tEXtComment (and no DAT+END?)
All image data won't be rewritten in the new file. the header, and all stuff is there.
Also the "tEXtComment" is not needed anymore since is an empty comment
don't write it to file (smaller size)
with a normal description the file will look like this
PNG+HDR+DAT+END ---> PNG+HDR+tEXtComment DAT+END)
Imi este indiferent ce cred ceilalti despre mine, caci oricum fiecare crede ce-i convine lui si nu ceea ce e real, doar ca mi-ar fi placut sa ma vada asa cum sint de fapt, nu asa cum poate le-ar placea lor sa creada. Ei au ales deja...
